So I've been asked by a few of you what makes this pump E85 compaible unlike others, here are two reasons;
A lot of pumps mainly BOSCH unit's are used with E85 today, in most cases there life cycle will be around 500hrs (w/ E85), these Walbro's have an expected lify cycle of 3000 hours (6x more)!
Secondly, if a pump design has exposed electrical terminals it is certailny not to be used with E85 fuel.
There are more but that's the two main ones.
  • 1 month later...
  • Replies 59
  • 3 weeks later...
Would there be issues getting the pump now at 280hp then down the track it wouldn't need changing when the car is doing around 400hp?
Hey!
I don't see any issues with that, only thing is in the short term the pump would be overkill for your set-up.
It would still function correctly.
- Brendan
  • 3 weeks later...
Just ordered one via the paypal button, however on the pec's online website it is 199? Why is 220 a SAU special but cheaper on your website??
Thanks
Thanks for your purchase.
We had not yet updated the site for new Walbro pricing, but we have done so now for the E85 unit. $210 + delivery online.
- Brendan
dam i should have got it from you.
would have saved myself 20 bucks.
ah well.. :(
next time.
So anyone got any proof of this pump holding over 500hp would really like to know as i'm going to be borderline 500hp after my new setup goes on
Jem reckon 350kw is borderline for the pump so i'm real curious
Cheers
Edited by sultanaz
  • 2 months later...
  • 1 month later...
  • 1 month later...
Just for reference I'm making 410kw on e85 with a single e85 walbro, maxed my injectors
There we go guys!
Customer from Sweden purchased a set of these (2x will fit in the assembly of a R35) just awaiting on some power figures now ;)
  • 2 months later...
  • 2 months later...
  • 4 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
