pva glue.
It still could be instrumental. Get it checked out and stop being a tight ass LOL. No honestly the readings are taken off the coil. Could be faulty wiring or connections or the tacho itself. get it check out by a mechanic or auto electrician.
good luck friend. :P
  • 3 weeks later...
  • 3 years later...
:( I had a similar problem and got auto repair after repair to hunt down the wiring, checked all the engine managment and sensor and was fine. Adventually I got of my ASS and replaced the Tacho all fixed, mind you the Tacho wasn't cheap!
Where is Tacometer sensor is located?
I think mine is bit out of scale...:D
cheers
Joe
There isn't a 'Tacometer[sic] sensor' as such, the ECU gets the angle of rotation of the camshaft from the CAS (Cam Angle Sensor), from this it can calculate the speed of rotation of the crankshaft, and using this generates a negative pulse for every rotation of the crank.
This pulse is the signal on pin 7 of the ecu, and that is what the rev counter uses.
Sounds to me like a problem with the rev counter instrument itself or the wiring between the ecu and instrument cluster, as there is very little that could go wrong with the ECU.
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
    • Wow. Pissy much? You on a mission to find old posts to argue with, or is this legitimately just because you're 5 years into a 1 day job?
