Sorry I haven't had time to update.
BC's are sold.
Dual din stereo surround sold, still have the triple gauges though.
Attessa unit sold to Ironpaw. ^^
Attessa relays sold.
Scotty, I'm after the cover for the fuel pipework under the RHS wheelarch, a couple of load area tie down hooks, and the red plastic cover over the Pos battery terminal in the engine bay.
Feel free to PM if they're available.
Cheers, Dale.
The cover should be fine, I haven't got into the back to check anything as Craig threw his ARX interior in the back and wedged it in tight. :P
As usual the red plastic cover for the positive terminal snapped off at the hinge the other day.
Did this car have a different ecu? Nismo, impul.....?
Not sure yet Craig. I doubt it.
If it did you would have snatched it before it came down, wouldn't you?
  • Like 1
How did the rear subframe fair from the rear end damage?
The non Hicas subframe seems perfect. I removed the suspension today and it looked fine. It was hit very high in the rear, at glass level. I think it was a 4x4 or truck bull bar. The Attessa unit was unharmed.
No great rush; red plastic cover makes me sad though. :/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
