  • 3 weeks later...
Hey scotty what condition is the passenger rear like? Im after a cut section off rear quarter panel near rear tail lights. Ill send u a pick when i can so you know what im talking about.
Hi Scotty
Finally got the exhaust in the other week and have been enjoying it immensely, but sensibly so (not around Plod). Now I have a rear sway bar that ratlles madly ... the drop links are shot. What has this got in the way of a sway bar? And how much to the same address please? Thanks.
Hey scotty,
As i tried to explain before bout the rear quarter panel. I have attached a photo of section i need. From the spot ill need an inch front and 2 inches above and below. How much for this cut section mate
Hi Scotty
I have the stock bar and links, they should be fine but have you priced new ones?
Hey scotty,
I can cut it out if you want, but surely a good panel beater can fix that small ding? I would have thought it would be harder to weld in a section than repair that?
+1
I damaged my rear quarter panel (drivers side) in a similar area, panel beater fixed it fine.
Hi Scotty, You say the interior is ARX tan leather.
Do you have the interior light in the boot (including little metal clip things)? Also after the card holder under the driver's side sun visor as mine has a broken leg. PM me with prices etc if you have them.
Cheers,
Jidge
No idea sorry, all the interior is stuffed into the back as Craig was too slack to re-fit it all when he stole the black leather interior. I'm sure it is in there somewhere...
I don't think there were any mats, the rest of the parts are somewhere in the back. It looks like I will have to pull it all out some fine day and sort through all the parts people have asked for. Will let you know soon.
I know there is a cargo blind, and the door switch, not sure about the mats...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
