Change of plans means that the semi slicks I bought brand new from Gordon Leven Motorsports 2 months ago have to go.
Yokohama Advan A048 225/45/17 Medium Hard compound a set of 4 tyres (doesn't include wheels)
They have never seen track, been driven slowly to Zen Garage once for dent removal and that is all. Easily less than 100kms done on them. Never had the chance to get any heat into them.
Photos coming soon.
Price: $1100 or nearest offer.
Pickup in Eastwood NSW preferred. Can post for keen buyers.
Contact Chris on 0424 660 535
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 4 months later...
Hi guys,
Got an Apexi RSM blue version up for sale. No G-sensor.
Came with my ECU and boost controller I bought but have no intention to install. Was told from previous owner it was working perfectly fine in his R32 GTR.
$150 or nearest offer
Genuine Made in Japan Nismo NS5R 16x7.5 +30 alloy wheels up for sale. These were the wheels that the Nismo S14 Silvia 270R came standard with.
Condition is good only one wheel has a tiny bit of kerb rash as seen in photo. Selling them as I've bought some R32 GTR standard wheels to use instead. They held air fine for the last 6 years I've had them and they don't have any cracks that I'm aware of.
$200 or nearest offer
20130423_160047.jpg 20130423_160055.jpg 20130423_160100.jpg 20130423_160105.jpg
20130423_160112.jpg 20130423_160122.jpg 20130423_160140.jpg 20130423_160146.jpg
Contact via PM thanks
Located in Northern Suburbs Sydney
Chris
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
