Hey guys I know this has probably been covered a million times but I can't seem to find a good answer..
I need to get my guards rolled and flared to fit 18x10.5 et 12 rim on the bak of as 34 gtt so some recommendations of some who does good work in Adelaide would be great cheers :P
https://www.sau.com.au/forums/topic/411051-guard-flaring-plz-help-p/
Got my guards rolled at Adelaide Radial Tyre but they won't do guard flaring because it can crease your guards, they told me best option is a body shop, since then i have been recommended to All Type Crash but haven't had a chance to go in
so you're going to pump them up, paint them and then fit over fenders and repaint them?
Sounds like you have too much money. Give me some
no no paint just a temporary fix to accomodate my wheels till I have the gtr guards welded on.. And im kind of wishing I didn't start this build because I could of had a real gtr by now lol
Yeah they told me the same thing when I rang this mornin... Might give all type a call couldn't be worse than the quote I got this morning from who ever has m & c dolye old number 500 bucks a corner wtf
Thats the realisation of all GTT owners who try and make a gtr
So TRUE but when I bought this car seven years ago it actually cost me the price of a gtr today... I'm never going to get my money back so I figure my aswell go all out on it... And it will be one of a kind there's not many people who have done the task with all genuine parts...
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
