1990 Nissan Skyline R32 Gts-t 2 door
Resprayed Green with Metallic gold
Sunroof completely removed and replaced with Lexan sheet
HICAS and Air con fully removed
Exterior:
Type-M side skirts and rear pods
R32 GTR Bonnet
R32 GTR Grill
R32 GTR front bar with N1 nostrils
R32 GTR N1 rear lip
GKTech Ganador Mirrors
Buddy Club P1’s powder coated Metallic Black 17x8 (front) 17x9 (rear)
235/45/17 Advan AD08 front and 255/40/17 Advan AD08 rear
Interior:
Suede Steering Wheel
Suede Gear and Handbrake Boots
Pioneer CD/MP3 Deck
Pioneer Front and Rear Speakers
Apexi EL Boost Gauge
AEM Uego (wideband)
Switches for low/high boost
Motec RPM Shift Light
Carbon Fibre Bride Vios III style fixed back driver’s seat
Carbon Fibre Bride Gias II style recliner passenger seat
R32 GTR rear seats
Takata style 4 point harness
Non Sunroof Roof Lining
Engine:
RB25DET from R33 S1
R33 GTR N1 Engine Mounts
R34 Gt-t Harmonic Balancer
Setrab oil cooler with Thermostat Sandwich plate
K&N Filter
Kinugawa T67-25g 10cm Turbo
Custom Stainless steel cooler pipe
600x300x76mm Bar and Plate Cooler
Trust Type-R Blow Off Valve
VH45 Throttle Body
Greddy copy inlet Plenum
Aluminium Fuel Rail
Deatschwerks 1200cc injectors (GTR)
GTR Injector resistor pack
Sard Fuel Pressure Regulator
Walbro 416L/hr E85 fuel pump in tank
Tomei Poncams 256 8.15mm
Gates adjustable exhaust cam gear
Gates Timing Belt
New water pump and timing belt tensioners
Yellow Jacket Coil Packs
6-boost Manifold
Tial 44mm MVR Gate
Custom 3” dump/front pipe
Decat Pipe
90mm Japanese Cat Back
Vipec Plug in ECU
Mac Valve controlled by Vipec (Boost Control)
R32 GTR Radiator
Driveline:
Nismo Clutch Pivot
HEL’s Braided Clutch Line
OS Giken Triple Plate
RB25DET Gearbox
Veem Engineering Custom Tailshaft
R32 GTR diff (2-way factory)
R32 GTR axles
R32 GTR Hubs
Brakes:
R34 Gt-t Front Calipers (310mm)
R32 GTR Rear Calipers
Cusco Brake Master Cylinder stopper
HEL’s Braided Brake Lines
QFM A1RM Brake Pads
RDA Slotted Rotors
Suspension/Steering:
Greddy Type-S Coilovers
R34 power steering pump
S13 power steering rack
Aluminium Steering rack lock spacers
Aluminium Steering Shaft spacer
HICAS Lock Bar
Kazama Castor Arms
R33 Gts-t Front Lower Control Arms
Performance Guru Front Upper Camber Arms
S15 Full Rear Subframe Conversion
Kazama Subframe Lock Collars
Performance Guru S15 Toe Rods
Performance Guru Rear Camber Arms
Performance Guru Rear Traction Rods
Performance Guru Rear Lower Control Arms
Whiteline Front Swaybar (adjustable)
R32 GTR rear Swaybar
Front and Rear Strut Braces
Current Power:
566rwhp 422rwkw at 1.7bar (8000rpm)
515rwhp 384rwkw at 1.4bar (8000rpm)
Track Times:
66.7 Barbagallo Long track (475hp, RE-55S R-comps, 7000rpm) Lots done since then, power suspension etc
58.0 Barbagallo Short track (current 515hp, AD08 street tyres, 7000rpm)
In terms of track times, it would be a lot faster than the 66.7sec long track as since them a lot of work has been done to the suspension and steering. The short track time was on street tyres so I would expect a few seconds less on R-comps. Turning the revs and boost up should net even more advantage.
Drags:
11.0 @ 132.5mph first pass before getting kicked out (520rwhp without cam’s and Vipec)
Have not run at the drags since the Vipec and Cams went in which made an extra 40rwhp everywhere on boost and came on boost a lot sooner so I would expect it well into the 10’s.
Overall it’s a very, very quick all rounder, it’s responsive enough to do motorkhanas and quick enough to keep even the quickest cars honest top end. Drives great on both the street and the track and would be perfect for drifting. As you can see there is a lot of money that has been poured into development of the car but it’s time to move on so I’m selling up. Everything on the car is fairly much less than 2 years old and still in very good condition. The Vipec is brilliant and controls the 3 boost levels by in cabin switches, it also is connected to the AEM UEGO so it constantly corrects fuel mixtures for perfect AFR’s while cruising around.
Looking for $20,000 ONO. Car is located in Perth, rego has just been paid for 6 months
Please call me on 0422426866
Edited by SimonR32
