  • Replies 43
Youtube Links.
Dropbox sucks for streaming.
I'm lost for idea's. Figured if it was a head gasket it would be constant smoke? Get worse with rpm's as pressure builds up? PCV valve cleaned, made 0 difference. Although it was gunked up and rattled when i shook it (think thats normal)
http://www.youtube.com/watch?v=UVU3XbimIsc
http://www.youtube.com/watch?v=G3aQ_biZaf0
Edited by Booki
Going to start taking it all apart tonight...just after i had put my sweet new -7's in :(
Anything else I should be changing while the head gasket is out?
Recommendation's on head gasket? (genuine, after market? Nismo? cometic?)
Edited by Booki
Just replace i with a standard gasket from Nissan. They aren't that expensive and are very good quality.
Get the cylinder head fully recoed while it's out. Valve regrind, stem seals, deck ect.
Get your injectors cleaned right before the head goes back on
Replace all the heater hoses
Still running stock injectors, worth spending the cash to get them cleaned?
Are there better options out their then the standard nissan gasket? While i would imagine they are good quality, I am planning on running 17-18psi boost on the -7's, would the standard gasket hold up? Or should i look at something after market?
Know any places that are reputable to get the head done? And rough costs involved?
Edited by Booki
We use stock gaskets in applications over 600hp and 30psi boost without issues.
If you do the job correctly, it will be fine
Anybody got any tips for taking the head off?
Both turbos are back out.
Cam gears and belt still on, looks like my cam timing is one or two notches out on the exhaust side...
Do people remove the head with the plenum attached? It looks like a bitch to remove the brackets hiding underneath the plenum.
Honestly surprised myself in how quick I was able to remove the turbos
Edited by Booki
Well for all those following, Heads off.
Now with the head out, I will send it off for a reco, though in the process their were some casualities. I ended up cracking it and just cutting a heater hose, and a two electrical connectors were damaged. Anybody know where to get a replacement heater hose and this particular electrical connector?
The other I am hoping to just open the connector, and solder/crimp it back down.
In the mean time I am hoping to get a neater engine bay setup, wanting to eliminate some hoses that are not required. Mostly the ones under the Plenum as they were a BITCH to get out!
Also, This wiring looks real dodgy and pox as, I don't think its standard/original wiring. Can anybody confirm? Then i will start following it up and eliminating it. Or at least making it neater.
Edited by Booki
Top hose in the pic that is broken - get it from Nissan (Usually the first place you should try)
The plug should be the same as Bosch 2 pin standard so I would try Repco etc for those. Pretty common plug. It won;t look the same but should still fit the Bosch 2 pin knock sensor.
The other wiring is anyone's guess
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
