Just back from Wakefield track day and I think I have died and gone to heaven. Car park full of Z32's, R31, R32, R33 and R34. Even the little GTiR Pulsar, S13's (both variants) S14 and S15's. About the only thing missing was the R390 LM but the incredible Black R34 GTR V-Spec (for sale) really made my day. I thought my R34 GTT had "presence" until I saw that. I now know what my next car will be and I don't car which wife/girlfriend/daughter I have to sell to get it.
Some great action on the track and some of the 32 GTR boys will be thankful for the AWD as some of them were seen dissappearing backwards/sideways/straight ahead off the track.
Bring on the next one I say.
:P
Muz
https://www.sau.com.au/forums/topic/41115-wakefield-nissan-nirvana/
yeah i just got back, that was an awsome day. that black 34 was beautiful. but id have to say that my fav car out there was the slo 32r R32 GTR, that thing was flying. did any1 else see the red 32 spin coming on to the straight in front of the two white 33's. that was close. bit of a pity the drift didn't go 4 ne longer :P
Thanks Ewen,
I liked that red R32 with C/F bonnet. Who owns that? Canberra local? and does he want to sell the wheels as they would look really great on my 34. Just kidding there.
I must get to meet you guys soon.
Cheers
Muz
Got pics coming...Saw you there Muz, looking good.
http://www.syndicatemotorsports.org/images...k_day/index.htm
thanx muz, i've still got a looong way to go b4 i'm happy with the car, the worst part being after you spend ridiculous amounts, you're back to square one when it comes to setup of car. which i've only done for circuit work only.
was spewing couldn't enter as last time i was racing there at the track the clutch cried 'enough'.
but yeah tell me bout it, plenty of nissans of all type which was good to see.
my volks are too small for you're car you're better going 18 or 19 that'll be really nice and make it stand out.
Yep, know exactly where you're at with the bottomless bucket but hey it's a passion isn't it. Thought about a bigger set of wheels but I like the economies that 17's present. I come from the far north and trust me, the roads (goat tracks) are an absolute disgrace. My last car was a hot Honda Accord with 17's and hit a pothole on the major highway between Cairns and Townsville and split two rims right around the circumference. Only travelling at 70 k at the time (in heavy rain). So I'm a bit wary about getting anything too large that reduces the amount of rubber between me and the road.
Why couldn't you enter?
Cheers
Muz
was too lazy to replace clutch from previous outing at wakefeild+am waiting for a dry sump setup so that i can push the car that bit more without worrying bout oil surge which gtr's suffer under extreme circuit work.
i must've been blind as i don't think i saw you're black beastie parked anywhere. but then again had a big night out so i was a bit on the 'howz it going' side.
I was parked between the two sets of garages just off the main access (first timer to Wakefield). Good to see a man enjoying his motoring.
LM R390/391 in Oz. Nah don't think so but that would definitely have made my day. I think the road going version went for something around the mill$, which with our roads and laws would make it a pretty pricey piece of kit to sit in a garage somewhere.
Muz
Thanks Angus, I agree entirely. The R34 GTR is one hell of a car and definitely my next ride.
GT-R32, Sorry bloke but I don't do the track thing anymore, just love to watch the younger generation do their thing. I'll stick to racing my AX-6 Rotax for the speed kicks.
Cheers
Muz
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
