As it says about got my 1972 240z l28 turbo need bigger car
Location in brisbane
Price $27500
Car is running the upgraded L28 Instead of the l24 and also is turbo
Running a t28 out of a s15 running 6psi vl turbo injectors has around 250Rwhp with biggeer injectors and more fuel
easy 300rwhp also has upgraded fuel pumps and fuel reg. Mircotech lt10 with hand controller
Has rota Rbx all round 17x9 on the front 17x9,5 on the back look massive with flares all round
The car has had a full resto from ground up all the interior is original no cracks super clean car for its age
zero rust
this thing turns so many heads its not funny and zero cop attention in the many years ive owned it
put it down to how clean it is most of them just give me the thumbs up
I would swap this car for something bigger like a EVO ,stagea autech, or a skyline with 4 doors Or GTR
0439809483
https://www.sau.com.au/forums/topic/411156-240z-l28turbo/
  • 1 month later...
phawwwwwwww ..... About as good as the half built wide body kitted one that i saw in a garage near Hornsby in 09.... although body not as wide or hnec phatttt.... GLWS ..... damnnnn this would be good for classic adel
https://www.sau.com.au/forums/topic/411156-240z-l28turbo/#findComment-6649459
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
    • Isn't the whole point of this integrated circuit thing to put a bunch of hardware all in one little package? Integration also brings its own benefits, at least in theory. If you were to put an electronic wastegate or do an N54-style vacuum wastegate that is normally fully open but closes under vacuum integrating everything allows you to do tricks like full wastegate bypass at cold start to warm the cats or in eco-mode under a certain torque request to reduce exhaust pumping resistance. Or full bypass as a limp mode if a certain amount of knock is detected. Or managing the compressor so it never reaches the surge point. None of this is strictly necessary per se but standalones generally have good enough boost control. PID control isn't exactly some crazy difficult problem to solve.
    • You've never bought something online before?
    • Hello everybody. I have no idea where to get a ethanol tester besides online and want to run a e30 mix in my bmw m2. In order for my calculator to work i need to know what ethanol rating the e85 pump is and this is my local station would anyone know or is it negligible to find specifically. Thanks🙂
    • Sometimes a piece of hardware built to do one job excellently, can be better than a piece of hardware trying to do 20 jobs "well enough".
    • My brother's old Pulsar had approx 10 year old tyres (crappy Zeix). The sidewalls split on all four tyres in the space of a week. I'd be paranoid on 10 year old tyres.
