Hey i have a 1985 Nissan bluebird TRX and i've blown the diff (i think pinion, haven't opened it yet). I was wondering if anyone might know a diff that will bolt straight up into the bluebird diff housing?? any help would be much appreciated.
Regards Tim
H165.
3.9 ratio. Whole rear end just missing one brake caliper.
Located ln VIC.
Factory diff housing has sticker. Good luck of its still there.
Also check compliance plate to see if it has trans axle code.
If there should be HA, HB etc to HF
HC is H165.
Then you need to choose your ratio that you want compared to what you have.
These are the ratios as far as I know.
3.364
3.545
3.700
3.900
4.111
4.375
4.625
4.875
  • 9 months later...
No , wrong . All Series 3 Bluebirds had a H190 diff with 30 spline axles .
Correct. All Series 3 Bluebirds had a H190 Diff.
Series 1 and 2 had the H165. From memory the Series 2 Wagon and possibly the Series 1 Wagon had a H190 as well.
Fecking hard to find as well!
Your best of signing up with the 910 bluebird forum if its still kicking around.
Edit, to add to that, 720 king cab Utes used H190's in the rear diff and R180's in the front for the 4WD version. However, the ratios maybe far too high for what you want.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
