So....I found a corner of the garage for a sandblasting cabinet (or as Kel called it, "the humidicrib")
But despite the name, I guess sand may not be the right thing to put in it.
So....I need to do regular car cleaning stuff....
what should I use, and where do I get it?
https://www.sau.com.au/forums/topic/411275-blasting-media/
As the guys have said it all depends on what sort of profile you need, Hare and Forbes are awesome BTW
Garnet will give a very good profile for painting provided the air-pressure is up to scratch, our old blaster was getting 10 micron profile, then we boosted it and could get a deadly 75 micron....beautiful for long term coating adhesion and letting etch primers get right into the metal.
Glass beads are good, but more suited for taking coatings off, and not for hard-core surface prepping, same for bicarb...which is nice and gentle and works on delicate substrates even plastics.
The king-kong of media is silicon carbide, it can be overkill on anything but the most hardened alloys or things that need some serious stripping. Silicon Carbide DES46 from A E Baker & Co
The thing to remember is never trust the sealing of the unit and always wear a proper dust mask/filter, I use a full-face Sundstrom SR 200
Secondly, always cover the glass observation panel with plastic laminate pouches of similar; something that can be replaced after the blast media has scored it, you just simply tape on a new bit of plastic instead of destroying your nice glass panel.
The harder the media = the quicker the nozel will need replacing.
And a decent compressor with an awesome capacity will save time and headache.
The guys here will give you good advice based on your requirements - www.blastech.com.au
Edited by 666DAN
https://www.sau.com.au/forums/topic/411275-blasting-media/#findComment-6581467
  • 5 weeks later...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
