Hey guys, been ages since I've posted here but thought since I now own an RB powered vehicle I might as well start up again!
Well It's been a little while between imports, but this came up and couldn't refuse my love for it!
1989 Nissan C33 Laurel.
Picked it up with almost no brakes (foot park brake used to load onto trailer) and unknown condition of auto trans, as well as everything else without driving it. From what I inspected everything was ok except rocker cover gasket, steering rack leak and the obvious wear and tear.
First things first, bought a set of S13 front knuckles, calipers, hubs and discs. These were a little smaller then what was on it. I only needed rear discs but the S13 SR20DET discs did not fit. The rears had the drum park brake setup with 4 stud so assuming the same as R32/33 NA brakes. They still had minimum thickness pads so it was ok to last this week.
Then why waste time putting my old wheels on it!
To pull it off I really need it super slammed, but with this exhaust I'm already having clearance issues on medium sized bumps :(
It currently has Tein coilovers and some form of a catback exhaust. HKS pod, Gates racing timing belt, and nothing else I've found yet. Sorry for a quick post but I'll upload a few more photos tonight and be sure to snap a few more this weekend on the hoist getting some TLC.
Not sure if its practical enough with the 15's, so considering a 5 stud swap for bigger brakes at the same time. If I go R33 gear, will I need a new coilover package? If I go S14, will the park brake cable need modification?
And if anyone has any RB20 manual swap stuff, or R32 handbrake setup available, let me know! I hate the foot park brake and auto!
Tom.
https://www.sau.com.au/forums/topic/411302-toms-c33-laurel/
Looks sweet man.
Looks like you've got room to tuck your exhaust up a bit more/make a new one.
First thing I did with mine was swap the foot brake for a proper handbrake while maintaining the auto transmission. I found a C33 handbrake lever with the first part of the cable,and i had a manual centre console spare, you just need to make up some kind of spacer or bracket, because the lever doesnt bolt straight to the floorpan and needs about 20mm clearance.
General consensus is that R33s have the closest handbrake cable length, if you're trying to get the entire handbrake setup from another car.
For R33 brakes you'll need 16s, and nothing will need to be done about coilovers, etc.
Just put your 5 stud hubs on, cut the shroud and flare it back to accommodate the bigger rotor, and use a thin long screw or screw extractor to remove the olive fitting inside the calipers, so you can use your existing brake lines (which have provisions to clip into your coilovers)
https://www.sau.com.au/forums/topic/411302-toms-c33-laurel/#findComment-6574033
Few more phots.
How I paid for the car (Beef Jerky included)
My mate came over on his Ruckus to give me a hand cleaning it up.
Yes, I am awaiting delivery for one of these bad boys!
Some of the crap I found in the boot.
JIC suspension receipt...obviously nto for this car since it has Teins.
Filthy engine bay.
The reason why I couldn't drive it home.
SSR's and my jealous mate.
Quite a lot of camber.
Balling interior, awaiting a boss kit for my wood grain Nardi.
Lowness/exhaust hang.
Gates racing.
Apexi spark plug.
Fixing up some rusted parts.
More photos this weekend!
Edited by Thomasino
  • Like 1
https://www.sau.com.au/forums/topic/411302-toms-c33-laurel/#findComment-6574988
As Andrew r said, this is really tidy by the looks of the pics, I wish mine was that clean :(
As for rims, personally I think nt03s or rpf01s may look awkward on it, dunno why, maybe it's te shape of them but IMO they belong on more sports looking cars.
My ideal setup for wheels is what you have right now I think ssr mesh on c33s are porn! It just needs a little more low and I definitely think it pull them off really well.
https://www.sau.com.au/forums/topic/411302-toms-c33-laurel/#findComment-6578689
Agree about the sporty look of RPF01's and NT03's on the luxury style car. Thinking maybe R33 GTR wheels or even R34. The brakes need an upgrade so considering s14/R33 combo.
And manual with HAND brake is definitely on the cards, already out of my mind driving it how it is! Interior has been swapped from the red velour and can't say if the leather/woodgrain is a standard option, maybe for the top of the line? Even has electric drivers seat! Not bad for 1989.
Exhaust definitely needs to be tucked/replaced, wouldn't mind a whole system but think a manual/handbrake comes first.
Quick photoshop with slammage and tint.
JZX81 with R34 GTR's
JZX81 with R33 GTR's (it's ahrd to find C33 photos...)
I wouldn't mind getting some larger SSR's...
https://www.sau.com.au/forums/topic/411302-toms-c33-laurel/#findComment-6584034
yeah i agree on 33 gtrs, they look great on laurels, as would 34 gtrs.
As for sets of larger ssr mesh, i used to look alot on Yahoo JP, in 5 stud its so hard to find decent ssr mesh in good sizes, i think i found one pair of 16 x 9's +18 mint condition, had jesse streeter bid on them for me, won the auction, then the seller removed the highest bid (mine through jesse) and i missed out on them. Was devastated.
Apart from that most are shitty widths and offsets, and i think i've only seen one half decent pair in 17s
https://www.sau.com.au/forums/topic/411302-toms-c33-laurel/#findComment-6584116
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
