Hi,
I’m having an issue with my 2003 V35 skyline. I have only recently had some new tyres put on the car as the previous tyres were on the way out. While they were getting fitted I was told that the front passenger side wheel has a noisy bearing. Driving it around now there is a significant amount of road noise coming from that particular wheel. The other thing I have noticed is when I turn a corner left, the noise disappears, when I turn right the noise changes to a sort of rotating "whummmmp whuumppp" (I guess?) type noise...this particular noise seems to come from everywhere.
While the new tyres were being fitted the guys there said I have a very noisy wheel bearing on the passenger front wheel. Could that explain the excessive road noise? Secondly in regards to the other tyres could it be the wheel alignment that is out? I had one done when the tyres were fitted.
Any help would be greatly appreciated!
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/
from the description of the noise : it seems to be a baring. the reason it will be on the left hand side of the car is also detectable from the turning noise
if you turn left the inertial force is greater on the opposite wheel IE you turn left but the right wheel gets the most pressure exerted on it.
The opposite happens when you turn Right Ie the greter the force is exerted on the left wheel. hence the reason the issue is with the left wheel. think of it this way when you turn left your body tends to lean right and vice versa.
if ur unsure take the car to a wheel and suspension specialist and they can check it out but id say by the sounds of it the diagnosis was correct .
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6573976
Thanks for that reply! Makes sense :)
I got a quote from Nissan to replace the front wheel HUB...$900! The guy i spoke to there said that there are several diffrent types of wheel hubs for the V35. Is that corect? Reason I ask is I have found one on Ebay (this particualr one has finished but there must be others around) here. Would that fit on my car? (As you can probably guess i know very little about this!).
I should say that its a 2003 coupe with the non brembo brakes.
Thanks again.
Edited by froggy88
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6573988
not sure if they would be different as i myself never had to deal with this on the V35's but considering you have 4 door and 2 door versions as well as auto and manual there may be differences. i would try and find a mechanic that works with import cars or a customs shop and see if he can help you. take your time and do your research.
As for Nissan …. Get a gun next time and tell the wanker he should shoot himself with it. 1st and last time I talked to a Nissan Steallership was when I asked for a cam shaft sensor and they wanted $600 … I ended up ordering it from the States for $50 from a genuine USA Nissan dealer. And it took me 15 min to replace Ausie Nissan dealers are just a joke
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6574100
Thanks for the help / advice Alexander I really appreciate it! Ill call up my ususal mechanic who deals with imports and see if they cant help me.
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6574164
I was having the same issue as you, exactly the same with the turning / noise stopping. I bought a wheel hub from the US for around $200 and got it fitted. The sound came back pretty quickly. Now I'm just leaving it.
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6574174
Edit: Yes I can see from your sig it’s a coupe 5AT like mine however mine is a 03. Not sure if there will be a difference?
Edited by froggy88
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6574183
  • 2 months later...
Hi all,
I had the left wheel hub replaced but the noise is still there and it even seems worse! Any ideas what else it could be? The mechanic did say that the right wheel hub also needs to be replaced and said the noise will not go away until this is done. I noted on the way home today that when I turn left the noise completely disappears...when I turn right the noise gets slightly worse.
Ill probably take it to a wheel/suspension specialist in the new year as most places are booked out.
Edited by froggy88
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6671455
that is pretty ordinary - he should have been able to diagnose which hub was at fault without even driving the car. the fact the noise is still there, if not worse, makes me think he got it wrong. maybe it was just the other side that needs replacing, maybe he's right and both sides do - but still - he should have been able to diagnose that up front.
it certainly sounds wheel bearing related. you might find that rolling along slowly in neutral with the windows down you can hear a 'tick tick tick' - another sure sign.
Have a read of this thread though, it will give you lots of answers:
http://zclub.com.au/forums/index.php?/topic/3662-front-wheel-bearing-hub/
Edited by SMOKEYC34
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6673884
Cheers SmokeyC34!
Probably the best way to describe the noise is like "Driving on a rail track" a sort of thunk thunk thunk that gets worse as speed increases...however just to mix things up it doesn't always make this noise, instead its just really loud road noise :\
I posted my issue on G35 driver and people are suggesting I check that the front and rear axles are greased. Apparently a common problem for the G35.
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-6674435
  • 3 weeks later...
  • 1 year later...
Well it turn out that it was the right hand side wheel bearing that was also faulty. Replaced an now its whisper quiet in the cabin..hooray!
I guess its good to change the wheel bearings in pairs then?
Hi mate, would you mind mentioning how much it cost you? I am having the same issue, as Im getting that noise from one of my rear wheels. Initially I thought, its just the wind beating against the car body or tyre noise until I started reading these posts. I would like to know how much could it possibly cost be if I have to replace any of my rear wheel bearings? And also, a tyre place like Bob Jane or Jax Tyres would be able to do it ?
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-7407590
Rear wheel bearings are a different setup to the front.
Front wheel bearings come complete with the hub pressed permanently into the bearing, so it is just a bolt off/on affair that anyone with some mechanical knowledge can do at home.
Rear bearings need to be pressed off/on, so unless you have a decent press at home, you will need a mechanic to do it for you. Any decent mechanic should be able to do the job though.
Parts are cheaper for the rears, but will be offset by the labour cost.
  • Like 1
https://www.sau.com.au/forums/topic/411307-v35-noisy-wheel/#findComment-7407857
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
