Afternoon Terry,
You'll be wanting to use that mailing tube as a weapon i would have thought by now???
Thanks again for your follow through!!.
Let me know if thers anything i can do to help. sounds like you have it sorted though..
Any idea what the damage will be on the photos?
Id even be happy to recieve it in a digital format if it helps keep costs down.
Matt my son has a DSLR, so I won't contemplate a cost at this stage Paul.
Thanks for being patient. I'll ask him about digital and a friend "jiffo" has mentioned to me already on your behalf.
Sounds good Terry.
Let me know how you get on.
I recently saw the stiching feature on a phone camera, was pretty cool for taking massive panaramic shots.
Not sure how it will go on flat 2D wiring diagrams though?
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
