hey everyone im not exactly an expert with motors n such and this is my first turbo car, i have a 94 R33 GTS-T and was hoping to mod her up enough to spank her hard,
i wanna be able to make 450hp+ safe tune, looking at spending an average of 10k or more if i have to , currents mods that i know of are,
:Front mount intercooler
:3` catback exhaust
:boost gauge
:turbo timer
and yeh thats off the top of my head, i recently found a 15,000km rb25det "got really really lucky on this 1" so the motor is really tight and drives very well
so was hoping you skyline fanatics could help us out and direct us in the right direction :))
https://www.sau.com.au/forums/topic/411370-modding-my-r33-gts-t/
all motor's out of Japan have only done 15,000 k's -_-
injectors
fuel rail/ fuel pump
ECU
Bigger Turbo
Coilpacks
BOV
Radiator
Boost Controller
Dose Pipe (For lol's)
Edited by cashie484
if this is a street car then you really wont have a need for all that power,
id stick with 400hp and a 3076 on 18psi with a 0.63 external for good response along with a great suspension/tyre setup..
if going 450hp plus then id go forged pistons and run a gtx3076 0.82external on 25psi with support mods..
Edited by SliverS2
apart from engine mods, don't forget to focus on suspension, brakes and drivetrain.
-Coil-overs / dampers
-Bracing
-1.5 or 2 way diff
-6 piston brakes or overhaul factory brakes
-Fatter rims with good tyres.
Add
Learn how to drive what it has now in a closed course , wet pan driving , brake control etc
Oh and turdbowl timers are a instant defect not a mod more of a wank
  • 2 months later...
Add
Sound advice above !! from everyone!
Search function will be your best friend =)
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
