Hello,
I've brought this up before with no solution, just wanted to try again. I've got a 2.5" catback exhaust with 2 resonators. There is a tiny muffler on the end of the exhaust,
my problem is that it still drones. Is it even possible to get a RB25de to have a clear sound without drone at all?
What are some people running on their Catback systems?
https://www.sau.com.au/forums/topic/411374-exhaust-sound-issue/
its the tiny muffler thats the issue, get a semi straight thru one,
my system has a hotdog resonator and a big oval muffler, the muffler is what muffles the drone the most, get a muffler thats semi striaight thru, so it curves inside, that will forces the gases to be muffled but not restricted , then your drone will come down ..
you need a either a large oval muffler or resonator .. police come straight after noisey cars..
Edited by SliverS2
are they hotdog resonators? thats odd because i have a 4L falcon with nothing but a large muffler on the back, and hardly any drone, sounds meaty actually. lol
Edited by SliverS2
doesnt look like much of a resonator, looks no better than a straight piece of pipe,
if it were me id have the big fat muffler on the back and an oval resonator, or id start there
WMDC5 is probably right, theres alot of honda's that sound like that,
a 2inch pipe size was probably better for the low power output too.
GL
hard to believe a good resonator and muffler wouldnt sound good without the drone, but i dont have an na, i know when i had a hotdog resonator with a cannon my car was extremely droning, i mean you got a headache after 5minutes
IMO whenever I have had just resonators that makes it drone. On my old motor na rb20 I had two hotdog style resonators sounded really nice under load but cruising it would be almost as loud and drone like crazy. Then I had the rear one replaced with an oval one and got rid of the drone almost completely, but made it sound not as good under load. Its a compromise really.
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
