Hey all
Just wanted to ask the question here as i know if i ask it on the main board i will get flamed. Just need help as not the most mechanically minded.
I just got my car back from Boostworxs with a new tune. Happy with it, response is better and 4000+rpm is awesome.
But the tune is conservative, which i asked for being my daily drive. Shaun said if i wanted over 350+kws on the same conservative tune a set of cams would do it.
What cams for an RB26 are a straight drop in? Like nothing else needs to be modified?
I dont want to buy a set and relise i have to change other things as well.
And whats the differance between all the Poncams that drop in? More lift = what? The bigger = ??
Want them for a bit more power and bit better response. A little lumpy idle might be nice to! lol
- Desno 800cc injectors
- 2860 -5 Turbos
- Tomei Cam gears
- Power FC and Controller
- Z32 Afms
- Apexi AVC-R Boost controller
- Trust 100mm Intercooler
- Tomei Expreme TI cat back
- Venom 100 cell 5 inch body cat
- Apexi Super Suction Kit Pods
- Air Box and Cold Air Intake
Engine
- Forged Pistons with standard Rods
- Metal head gasket
- GTR crank
- ACL bearings
- Extended Sump
- New Rings
- Honed Bore
333.4kws at 18 psi
Edited by Adz2332
https://www.sau.com.au/forums/topic/411375-cams-advice/
Reading this page http://www.tomei-p.c.../efr_index.html
Type B seems the way to go 260 and 260 but reading down further is confusing me. What is the mid low hi in type mean?
Edited by Adz2332
https://www.sau.com.au/forums/topic/411375-cams-advice/#findComment-6575385
Yer he said he will email me later today.
If its a streeter my guess is you'll be wanting poncam type B's (i see you already have adjustable cam gears)... You wont need to change springs for them. I believe the difference is the Type A is a lumpier cam which will get you more power than the B's but the B's have smoother delivery.. I could be wrong though
-D
Edit - Actually I got that completely wrong. Type A is meant for stock/N1 turbos and Type B is meant for larger turbos - and since you have the -5's, probably both of them would suit - info direct from Tomei - http://www.tomei-p.co.jp/_2003web-catalogue/e070_cam_RB26.html
https://www.sau.com.au/forums/topic/411375-cams-advice/#findComment-6576966
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
