sold my gtr some stuff i got laying around
black gtr bonnet has a dent in has n1 lip $400
r32 gtr door trims in very good condition both $150
caster radius arms adjustable no brand on them look solid $100
r32 door windows excellent condition $200
gtr rear sway bar $80
carbon canards new $100
polished plenum gtr $150
twin turbo pipe $100
rb26 rocker covers/camgear cover/top cover(spark plugs) $370
rb26 head has been ported is bare atm has most bits with it valve/shims etc $600
new valve springs paid $395 now $250
r32 gtr crank $200
varex muffler not remote $150
nismo suspension not coil overs $200
mine centre guage $250
water resevoir bottle r32 $40
waste gate r32 gtr $100
r32 kick panels like new left and right $100
ganador mirrors r32 $300 in white
located near campbelltown nsw
willing to ship at buyers expense
all prices ono
send offers through like to empty shed out
https://www.sau.com.au/forums/topic/411413-gtr-stuff/
also got some enkie 18x10.5 +15 (blue they were a limited edition last year) offset with 295/30/18 yokohama ao50 rubber
tyres have done 3 track days
wheels $1500
tyres $1200
got some hankook ventus rs3 285/35/18 done about 3000kms $1250
ultra racing 4 point front lower strut bar is new never used $150 i paid $400 for it suit r32
alcon 380mm front brakes come with everything but lines suit all skylines and s14/15 $6000
https://www.sau.com.au/forums/topic/411413-gtr-stuff/#findComment-6576708
pics sent through also have a new 4 point harness RPM brand $50
its a 5 point harness not 4 point comes with all fittings as well
also have standrd GTR blow off valves bolted to piping
https://www.sau.com.au/forums/topic/411413-gtr-stuff/#findComment-6578037
also got nismo oil cap $35
r32 air con display $50
HDI boost control plug in and use has everything that is needed with it $100
ethanol content analyzer (new never used) has in car screen and sensor this cost me $800 selling $550
https://www.sau.com.au/forums/topic/411413-gtr-stuff/#findComment-6578815
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
