Coupe or sedan?
I have a JIC Magic Spartan DE I bought from their reseller (Bullet exhausts) in the US.
Look on ebay. Its pretty cheap, mine was under 800 delivered
I'm really happy with it; except my compliance cats made my exhaust a little bit shorter than it should... makes the fitment a bit off.
Going so sort that with some high flow cats eventually.
https://www.sau.com.au/forums/topic/411473-exhuast/#findComment-6577714
http://www.ebay.com.au/itm/JIC-Magic-INFINITI-G35-2door-CVP35-OVAL-SUS-Exhaust-/330451322538?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cf06f06aa#ht_897wt_1165
I really like the sound; it isn't very droney (except for when the rear clamp leaks; but as I said, that;s because my compliance cats have shortened my exhaust by several inches)
https://www.sau.com.au/forums/topic/411473-exhuast/#findComment-6577910
depends if you want a cannon on the back or not...
cheapest option is to drop the midpipe and get an exhaust shop to knock up a straight thru pipe
or listen to the difference in setups i made at home
http://www.skylinesaustralia.com/forums/topic/409286-dual-exhaust
if you can find an exhaust parts wholesaler, you can buy things much cheaper
https://www.sau.com.au/forums/topic/411473-exhuast/#findComment-6591704
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
