Here's the setup I am currently running.
Power is a tad over 900awhp or 671kw's @ 30 PSI of boost on E85
PB of 8.97sec at 150mph makes it 2nd Fastest Street Tyred Manual Gearbox GTR in the World
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Jun 295 degree x 11.8mm Lift
-Full Tomei Valvetrain.
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-2000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
-5 x Bosch 044 fuel pumps
-Peterson 4 stage Dry Sump Setup
-4 Inch Exhaust
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
Here's what 8sec with H-Pattern Looks like. :yes:
  • Like 1
When it got weighted at Jambo it tipped scales at 1440kg that's was with half tank fuel and no driver. Car has all factory glass and steel panel except the bonnet. So pretty much weighs same as a stock R32 which is a surprise lol
Hi everyone,
About time we posted this up - here are the specs on our "NITTO" R34 GT-R:
STANDARD RB26DETT bottom end
ARP headstuds
Nitto Headgasket
Standard oil pump
Custom head by Mercury Motorsport
6Boost mani
Precision 7675BB turbo
Twin Precision wastegates
4" exhaust custom made
Haltech Platinum Pro ECU etc.
Upgraded fuel system
Splitfire coils
100mm thick FMIC
Custom i/c piping
OS Giken sequential gearbox
Power: 622awkw/845awhp @ 43psi (ran in 5th gear, to keep the 1:1 ratio due to gear changes, 6 straps holding it down)
Could we bother you for a dyno sheet with RPM on the bottom axis? It would be most appreciated!
It runs a stock standard RB26 bottom end, not N1 block...
Yes, we ran a 10.3 @ 142mph last night - first run out of two, first time it's ever been raced down the quarter with the sequential & over 600hp...
Bogged down at the start too. In full street trim - 20" rims with shitty Hero tyres.
This car weighs around 1700kgs including the driver & massive brakes.
Will post up vids of the run tomorrow :)
How long is it going to last at that power??? Who knows!!! It's been on over 600awhp for nearly 2 years now, stepping it up to 800+ early September this year. Has done Powercruise Bris, Powerplay Syd, SAU airport runs & 2 runs last night. Yes, we have a 3.2 that's almost ready to go in :)
If you want dyno graphs, various vids etc. then check out our Mercury Motorsport Youtube channel ;)
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
