So lets clear up some of the rumors......
The original Nitto 2.7L blew a head gasket at power cruise in 2010 when we were running the GT47R through a mixture of too much boost and also too much coolant temp (it copped a cainning!). We didn't time to repair it before Autosalon, so we decided to run the car on the dyno as it was. On 40+psi it made 1072hp, but had sucked in some coolant and damaged a rod. This caused a rod failure AFTER autosalon at a photoshoot under light load destroying the N1 block. The engine was removed and replaced with a standard 05U rb26 and a T04z setup as we wanted a street style setup and we had spent a lot of funds to get to that point. The stroker kit was inspected and any damaged items were replaced and since then we have sold/fitted the 2.7L into a customers car.
For the past 2 years we have been running the standard engine and with great success, using E85 and generally running around 30psi boost. I now personally tune the car (I didn't with the 2.7L engine, it was one of my staff) and switched to a HALTECH ECU. The T04Z was getting boring, so we had a play around with a few turbos (doing more R&D) and eventually we installed the Precision 7675. I wanted to see how far we could go with the standard components as 2J's are always referred to as unbreakable and I thought it was time an RB got some credit! It went into the 700's (hp) and I was having a chat with Mark @ Godzilla. I asked if he thought 800hp was possible and he kinda laughed at me. I dont mind a challenge, so I had a new goal of 800hp. We got to 805hp and this particular engine was hanging in there pretty well! We had run 30psi, then 35psi, then 40psi! it just wouldnt break! Hell we even threw a 100 shot of gas on there for a bit more response. To me it is experimenting, but on my own gear. It allowed us to play with the Haltech ECU and use many more of its features other than just timing and fuel. It runs everything including the NOS, flat shift (when we put the sequential in there), coolant pressure protection, complete engine protection (temps, pressures etc) full EGT on each cylinder and also post turbo....the list goes on.
We are the first to realise the standard engine is a timebomb (yes we are realistic!) and wanting to do something different instead of just another 2.7L (as we had already done that), we have been building a 3.2L Nitto engine over a period of time whilst using the standard engine. This engine is getting the works including sleeves, billet main caps, 4wd girdle plate and a few other little goodies. This will be combined with a new custom head (bigger and better!) and a larger precision turbo. Our goal is to build an amazing street car with 1000hp at the wheels that can be used at Powercruise events, off street drags, air strip run, 1000m races etc.
We love our 34 GTR so stay tuned for more updates as we fit the new engine and attend more events, showcasing it performance.
Trent
Trent
Damn. I liked the rumor that the rod bent BEFORE the autosalon dyno run. lol
It's sounds like you have had alot of 'fun' with this car over the past two years and i'm actually keen to see you install the 3.2 and poke it with a stick.
I look foward to seeing furture updates with this car.
Hahaha! We liked ALL of the rumours... :P
We also like the one where apparently we're using an N1 block as our 'stocker' that's currently making 845awhp!
It's all about R&D, it's been a lot of fun pushing boundaires & we're blown away with the power that we've got out of that stock 26 so far... It's a credit to Trent's tuning.
Looking very forward to popping the 3.2 in, that's for sure :)
Up until 1 month ago, it had standard sump with the oil just filled to the top line on the dipstick, as you would with any car. When we changed the diff ratios, we installed a 9L sump and again filled it to the top line of the dipstick. WE HAVE NEVER OVER FILLED THE ENGINE WITH OIL!
You could have at least wacked a set of billet pump gears in when you had the sump off you stingy bugger :)
Edited by SimonR32
anything under 6l with 800hp and the bearings would be toast a long time ago.
How? What diffrence does 800hp make? Any engine weather it be a Suzuki mighty boy or a ride on lawn mower, if it don't the right amount of oil in it, the bearings will b toast.
It doesn't matter how much power you got.
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
