So lets clear up some of the rumors......
The original Nitto 2.7L blew a head gasket at power cruise in 2010 when we were running the GT47R through a mixture of too much boost and also too much coolant temp (it copped a cainning!). We didn't time to repair it before Autosalon, so we decided to run the car on the dyno as it was. On 40+psi it made 1072hp, but had sucked in some coolant and damaged a rod. This caused a rod failure AFTER autosalon at a photoshoot under light load destroying the N1 block. The engine was removed and replaced with a standard 05U rb26 and a T04z setup as we wanted a street style setup and we had spent a lot of funds to get to that point. The stroker kit was inspected and any damaged items were replaced and since then we have sold/fitted the 2.7L into a customers car.
For the past 2 years we have been running the standard engine and with great success, using E85 and generally running around 30psi boost. I now personally tune the car (I didn't with the 2.7L engine, it was one of my staff) and switched to a HALTECH ECU. The T04Z was getting boring, so we had a play around with a few turbos (doing more R&D) and eventually we installed the Precision 7675. I wanted to see how far we could go with the standard components as 2J's are always referred to as unbreakable and I thought it was time an RB got some credit! It went into the 700's (hp) and I was having a chat with Mark @ Godzilla. I asked if he thought 800hp was possible and he kinda laughed at me. I dont mind a challenge, so I had a new goal of 800hp. We got to 805hp and this particular engine was hanging in there pretty well! We had run 30psi, then 35psi, then 40psi! it just wouldnt break! Hell we even threw a 100 shot of gas on there for a bit more response. To me it is experimenting, but on my own gear. It allowed us to play with the Haltech ECU and use many more of its features other than just timing and fuel. It runs everything including the NOS, flat shift (when we put the sequential in there), coolant pressure protection, complete engine protection (temps, pressures etc) full EGT on each cylinder and also post turbo....the list goes on.
We are the first to realise the standard engine is a timebomb (yes we are realistic!) and wanting to do something different instead of just another 2.7L (as we had already done that), we have been building a 3.2L Nitto engine over a period of time whilst using the standard engine. This engine is getting the works including sleeves, billet main caps, 4wd girdle plate and a few other little goodies. This will be combined with a new custom head (bigger and better!) and a larger precision turbo. Our goal is to build an amazing street car with 1000hp at the wheels that can be used at Powercruise events, off street drags, air strip run, 1000m races etc.
We love our 34 GTR so stay tuned for more updates as we fit the new engine and attend more events, showcasing it performance.
Trent
Trent
Damn. I liked the rumor that the rod bent BEFORE the autosalon dyno run. lol
It's sounds like you have had alot of 'fun' with this car over the past two years and i'm actually keen to see you install the 3.2 and poke it with a stick.
I look foward to seeing furture updates with this car.
Hahaha! We liked ALL of the rumours... :P
We also like the one where apparently we're using an N1 block as our 'stocker' that's currently making 845awhp!
It's all about R&D, it's been a lot of fun pushing boundaires & we're blown away with the power that we've got out of that stock 26 so far... It's a credit to Trent's tuning.
Looking very forward to popping the 3.2 in, that's for sure :)
Up until 1 month ago, it had standard sump with the oil just filled to the top line on the dipstick, as you would with any car. When we changed the diff ratios, we installed a 9L sump and again filled it to the top line of the dipstick. WE HAVE NEVER OVER FILLED THE ENGINE WITH OIL!
You could have at least wacked a set of billet pump gears in when you had the sump off you stingy bugger :)
Edited by SimonR32
anything under 6l with 800hp and the bearings would be toast a long time ago.
How? What diffrence does 800hp make? Any engine weather it be a Suzuki mighty boy or a ride on lawn mower, if it don't the right amount of oil in it, the bearings will b toast.
It doesn't matter how much power you got.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
