This thread need photos... hopefully both of these items are going to get me over the 500kW mark.
S300SX with 66mm compressor wheel (same wheels as EFR9180) and one of the two Weldon fuel pumps.
Do they drop in the tank Mike ?
No, that one is from the surge tank to the rail. I have never been so excited about fuel pumps (and it is not my phone either).
Just has to be said, Geoff from Full-Race is one of the most helpful and friendly business owners I know. Top dude!
Why 2x weldon pumps?
These style of weldon pumps will pump anything from vegi oil right through to nirto methane and everything in between... I love my 2345-A :yes:
J.
J.
One inline from tank to surge tank, then the above from surge tank to rail.
They probably would, but not on the recommendation from my contact at Weldon, this is being built for petrol only.
Yes, they are easy to love :)
Ill chip in, about 5 weeks ago I purchased a 34 gtr, after having a 2spd auto r33 that did a 9.95 on my first time driving it, the straight line stuff got abit boring. My 34 is the old Jetters Edge car, has got a fully built n1 block tomei 2.6 motor, big cams, idles like a bridgeported rotary haha bounces from 1100-1300rpm. is making 680awhp atm on pump fuel, has all the stuff ready for e85 and gas so in a few weeks i shall update with its final power figure, previous owner built it for 600kw (whether that was engine or awhp, i dont know). Also looking at getting a PAR dog engagement gearset, 1st-4th, pretty cheap. Any reccomendations? wont be street driven for another 1.5 years, p plates fn suck but this keeps me out of trouble lol have a garage for sydney powercruise aswell, who is goin? :)
Nice username :ph34r:
Ill be at Powercruise, will be keen to have a look at your beast!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
