So lets clear up some of the rumors......
The original Nitto 2.7L blew a head gasket at power cruise in 2010 when we were running the GT47R through a mixture of too much boost and also too much coolant temp (it copped a cainning!). We didn't time to repair it before Autosalon, so we decided to run the car on the dyno as it was. On 40+psi it made 1072hp, but had sucked in some coolant and damaged a rod. This caused a rod failure AFTER autosalon at a photoshoot under light load destroying the N1 block. The engine was removed and replaced with a standard 05U rb26 and a T04z setup as we wanted a street style setup and we had spent a lot of funds to get to that point. The stroker kit was inspected and any damaged items were replaced and since then we have sold/fitted the 2.7L into a customers car.
For the past 2 years we have been running the standard engine and with great success, using E85 and generally running around 30psi boost. I now personally tune the car (I didn't with the 2.7L engine, it was one of my staff) and switched to a HALTECH ECU. The T04Z was getting boring, so we had a play around with a few turbos (doing more R&D) and eventually we installed the Precision 7675. I wanted to see how far we could go with the standard components as 2J's are always referred to as unbreakable and I thought it was time an RB got some credit! It went into the 700's (hp) and I was having a chat with Mark @ Godzilla. I asked if he thought 800hp was possible and he kinda laughed at me. I dont mind a challenge, so I had a new goal of 800hp. We got to 805hp and this particular engine was hanging in there pretty well! We had run 30psi, then 35psi, then 40psi! it just wouldnt break! Hell we even threw a 100 shot of gas on there for a bit more response. To me it is experimenting, but on my own gear. It allowed us to play with the Haltech ECU and use many more of its features other than just timing and fuel. It runs everything including the NOS, flat shift (when we put the sequential in there), coolant pressure protection, complete engine protection (temps, pressures etc) full EGT on each cylinder and also post turbo....the list goes on.
We are the first to realise the standard engine is a timebomb (yes we are realistic!) and wanting to do something different instead of just another 2.7L (as we had already done that), we have been building a 3.2L Nitto engine over a period of time whilst using the standard engine. This engine is getting the works including sleeves, billet main caps, 4wd girdle plate and a few other little goodies. This will be combined with a new custom head (bigger and better!) and a larger precision turbo. Our goal is to build an amazing street car with 1000hp at the wheels that can be used at Powercruise events, off street drags, air strip run, 1000m races etc.
We love our 34 GTR so stay tuned for more updates as we fit the new engine and attend more events, showcasing it performance.
Trent
Trent
Damn. I liked the rumor that the rod bent BEFORE the autosalon dyno run. lol
It's sounds like you have had alot of 'fun' with this car over the past two years and i'm actually keen to see you install the 3.2 and poke it with a stick.
I look foward to seeing furture updates with this car.
Hahaha! We liked ALL of the rumours... :P
We also like the one where apparently we're using an N1 block as our 'stocker' that's currently making 845awhp!
It's all about R&D, it's been a lot of fun pushing boundaires & we're blown away with the power that we've got out of that stock 26 so far... It's a credit to Trent's tuning.
Looking very forward to popping the 3.2 in, that's for sure :)
Up until 1 month ago, it had standard sump with the oil just filled to the top line on the dipstick, as you would with any car. When we changed the diff ratios, we installed a 9L sump and again filled it to the top line of the dipstick. WE HAVE NEVER OVER FILLED THE ENGINE WITH OIL!
You could have at least wacked a set of billet pump gears in when you had the sump off you stingy bugger :)
Edited by SimonR32
anything under 6l with 800hp and the bearings would be toast a long time ago.
How? What diffrence does 800hp make? Any engine weather it be a Suzuki mighty boy or a ride on lawn mower, if it don't the right amount of oil in it, the bearings will b toast.
It doesn't matter how much power you got.
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
