Mates vl calais 1400kg plus driver, with 385rwkw ran 139mph.
Same guy now has aprox 550rwkw vl running 9.0@155 mph.
cozza manual ran 139mph at heathcote, so maybe less elsewhere, and he took the interior out aswell, it ran less mph before that
I really only see it running 134-135mph with interior in it at another track really
cheers
darren
Didn't the R32 GTR "JUN" run 155mph with around 850hp?
R32 GTRs are A LOT lighter than R34 GTRs... We are unable to run smaller than 20" rims on NITTO due to the massive brakes. We cannot put 20" semis on it either as they simply won't clear the rear guards (not keen on damaging the House of Kolor paint!)
You cannot compare a VLT or any other car to this one, either than another R34 GTR that has similar power, a sequential gearbox & was run with 20s with normal "street" tyres :)
Remember - that 10.3 @ 142 was Trent's FIRST EVER run down the quarter in NITTO. To do that time & trap speed straight off the bat was freaking awesome, a lot of wheel spin was experienced on the launch as well so a 9 was not out of the question. We will be putting smaller brakes on the car so we can fit smaller rims & some MT Streets, then take it back down in due course - join the RH9 club!
You're not taking into consideration the weight of the 6-pot caliper/355mm rotor fronts & 4-pot caliper/320mm rotor rears! ;)
How will that equate to 13mph slower down the 1/4? Funny you mention the tyres, they will only matter for the ET. My dads old 350rwkw R33 was trapping 130mph on streets tyres and MT streets but times were hugely different.
Fark there are some serious haters in here...lol
No hate from me, its an amazing car and its even more amazing that its making that power on a standard bottom end. Tuned very well, just curious as to how a small weight increase will equal such a large difference in trap speed.
WEIGHT!!!
Redline is at 8000rpm due to standard bottom end.
Edited by NITTO R34
Here's the setup I am currently running.
Power is a tad over 900awhp or 671kw's @ 30 PSI of boost on E85
PB of 8.97sec at 150mph makes it 2nd Fastest Street Tyred Manual Gearbox GTR in the World
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Jun 295 degree x 11.8mm Lift
-Full Tomei Valvetrain.
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-2000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
-5 x Bosch 044 fuel pumps
-Peterson 4 stage Dry Sump Setup
-4 Inch Exhaust
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
Here's what 8sec with H-Pattern Looks like. :yes:
This may be covered but whats the exact reasoning for 5 044s?
One was a lift pump to surge tank and the other 4 feed the fuel rail, the car only needed 3 to run that power and the 4th one was a spare just incase one dropped out during a run. Doesn't matter anymore that fuel system has been sold and a new Aeromotive Mechanical fuel pump will be going in along with a smaller 15L Fuel Tank. All in the aim of saving some weight.
What do you think of the Precision 7675?, tried any GTX4202's to compare to?
cheers
darren
Everyone keeps running these large frame turbo's and for what, they take up all your engine bay space, you need a big f**k off steam pipe manifold to hold them up and they don't produce as much HP as the smaller turbo's. I got the shit bagged out of me when i said i was gonna run a 8sec pass with a T62R. Well guess what i done it, with a H Pattern box no doubt, no weak sequential shit that breaks every 3rd run for me. There are a lot of non believer's out there that think everything is impossible, i like to think the opposite. What is possible? And i am thinking that breaking the 8.47sec pass set by the RH9GTR with a Auto box is possible with a H Pattern box. Time will tell but i am confident this is very achievable considering how easy it was to run a 8sec pass, and the car potential is just starting to show.
    • The interesting part of tests like IM240 is they measure the exhaust output. But they never measure the gases going into the engine... Imagine doing the test in a densely populated city with higher CO2 levels around... Instant disadvantage...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
