Engine is out of the car for a couple of reasons. One of them is due to the fact that for some reason the exhaust cam timing had been mysteriously retarded 13 degrees (when it was in another workshops care). Subsequently, the larger valves appear to have been bent.
Will rectify and then probably go back on the dyno in August with full beans.
  • 3 months later...
Made 580RW KW at GT Garages first dyno comp a while back.Slowly getting the old gtr back on the road again here are some parts ive collected over a bit of time Direct twin plate clutch Caple motorsport plenum with 102 mm throttle body 290 11.5 cams with oversize supertech valves and double valve springs bRAND NEW NISSAN HEAD Ross metal jacket with new crank and cam sensors does away with std nissan CAS also brackets and pulleys for dry sump set up50mm pro gate 2000 fuel Nitto DBS headgasket 10.5 to 1 comp JE pistons 2000cc injector dynamics injectors and rail kit 60 psi EBOOST 2 with 4 port solinoid Got coming A GT55 turbo Kernen manifold
http://www.youtube.com/watch?v=CmIEehrvl6w
Any 2.5L Rb25det here?
There are RB25s with that kind of power, don't know of any specifically on SAU off hand. JEM will be tuning one soon which I am expecting will make that power with change in the next few days... most people just go to RB30, which is what I was going to do - or may still do.
  • 4 weeks later...
That is insane man, nice work - awesome wide power delivery! How does it drive? Any plans to hit the strip with it?
Mentioned on the JEM page, unless the compressor profile from the 4094 has been tweaked there might not be a huge amount more flow left in it... Not that 700whp is anything to sniff at haha
Here is my entry
RB26, stock bottom end
Grex 9.1mm cams
ARP2000 head Studs
Greddy 1.2mm head gasket
Greddy manifold and gate
Precision 6262 CEA dual ball bearing 0.84 T4 divided rear
HKS Type-R 100mm cooler
United E85
530rwkw at just under 2bar
  • Like 1
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
