Hey all,
I've just got my hands on a copy of dyno2000 (looking for 2003 if anyone has it)
and i'm trying to find the stats to simulate an rb25det and other skyline types. so far i've found the bore and stroke (thanks to meggala's site) but thats pretty much all.
These are the variables with the ones i know filled in.
25det
Cylinders 6
Bore 86mm
Stroke 71.7mm
cyl vol 416.49cc
Total vol 2498.95cc
4 valves per cylinder
Intake valves 2
Exhaust valves 2
intake diameter : unknown
ext diameter : unknown
Compression ratio : 9.something??
Induction flow : approx?? cfm
Stock turbo flow : cfm
Pressure ratio : ??
surge flow : ??
And a whole pile of cam stuff i have no idea how to figure out or even explain.
I've tried searching for the above and really cant find much.
Any assistance would be useful, and others might find the info of value aswell.
look forward to hearing your replies.
cheers
M
https://www.sau.com.au/forums/topic/41149-stock-rb26-and-26-stats-for-dyno2000/
I have this program too. Putting all of the below stats into it showed a graph which was very similar to what Nissan shows as factory output of the RB26DETT in an R32 GTR:
RB26DETT
Bore: 86.0mm
Stroke: 73.7mm
Intake Valve: 34.5mm
Exhaust Valve: 30.0mm
Compression ratio: 8.5
Lifter: Solid
Cam Specs @ seat to seat
Int Lift @ Valve: 8.58mm
Exh Lift @ Valve: 8.28mm
Intake Valve Open (BTDC): 7.0 degrees
Intake Valve Close (ABDC): 53.0 degrees
Exhaust Valve Open (BBDC): 63.0 degrees
Exhaust Valve Close (BTDC): 7.0 degrees
with the above specs, all the other data will be automatically calculated by Dyno2000, like cylinder cc volume, total cc volume, combustion cc volume, and camshaft specs like Lobe centres, valve overlap, int & exh duration. It's all maths... very interesting program once you start playing around with the turbo specs, although it is hard to find data on the CFM flowrates of certain turbos unless you went to the trouble of going to a turbo specialist and flowbench each and every turbo... Have fun, but use it as a GUIDE only... I have the save file of the above specs i gave you if you want it.
Cheers,
Zen.
RB26DETT ex valve closes 7BTDC (there's 0 overlap). Although it actually depends which RB26DETT you are dealing with. Zensoku quoted for the R32 version.
For the R33 (R33 N1):
In opens 7BTDC (7BTDC), closes 53ABDC (53ABDC)
Ex opens 63BBDC (58BBDC), closes 7BTDC (2BTDC)
R34 (and R34 N1):
In opens 3BTDC, closes 57ABDC
Ex opens 59BBDC, closes 3BTDC
RB25DET also depends which RB25:
R33:
In opens @TDC, closes 60ABDC
Ex opens 57BBDC, closes 3ATDC
R34:
In opens 1ATDC, closes 57ABDC
Ex opens 51BBDC, closes 1ATDC
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
