Guest INASNT
I need a few calculations which i could do myself but i cbf getting out notes or books to work em out.
Questions :
If u were travelling at 130km/h for 800m how long (seconds) would it take to travel that distance?
How long would it take to come to a complete stop from 130km/h and how many meters to stop in a normal VT commodore V6?
How many seconds would a VT commodore exec take to accelerate to 130km/h and and how many meters would it take for it get to 130km/h?
https://www.sau.com.au/forums/topic/41150-questions-for-the-maths-gurus/
  • Replies 99
yes you could work out the stopping distance/time but there are many things that are required, weight, brake size, caliper dimensions, brake pad material and others as well i think, not worth the effort really
same for the acceleration, many factors that affect the time and probably wouldnt be overly accurate
Guest Munky
22.153846...... seconds to go 800 metres
To do this just work out how many metres per second the car is travelling at (its speed / 3.6)
Then divide 800 by the figure you get from the above calculation.
Basically its just a case of manipulating the simple identity
Velocity = Distance / Time once you get the velocity in m/s
its pretty hard to do the acceleration question without some figures to go with it (ill look for some)
Guest Munky
Using the figures of a supercharged 5.7L V8 Commie VT (So it's inaccurate - I couldnt find figures for the one u specified)
Assuming it accelerates at constant acceleration, and using the figure of 5.89s 0-100kph
v = u + at
0 = 100 + 5.89a
therefore a = approx. 17 km/s
So now using v = u + at again
130 = 0 + 17t
therefore t = about 7.64 seconds
Now just doing a simple calculation of distance travelled = 1/2vt
The distance travelled is about 138 metres
I think that should be right but I havent done any mechanics/physics questions for about 7 months (since I finished hsc) It sounds right though (at least for a supercharged 5.7L v8)
I think you'll find that you can't do the stopping question without a figure on the deceleration figures of a commie.
Guest Munky
If u go by 1/4 times for a exec commo dont they do 16 in the 1/4, but at what speed?
It's almost impossible to figure this out because once your doing 100km/h obviously your car won't accelerate at the same rate as it was for 0 - 100. So its speed might only increase by 40km/h in the last 10 seconds of the 16 secs (as opposed to the 100 km/h it increased in the first 5.98 seconds if ur using the supercharged specs)
That's why the original calculation probably isnt very accurate either, since I just took the average rate of acceleration and assumed it was constant for the entire 0 - 100 (then kept assuming it was constant till 130km/h) In reality it would take longer since the car won't increase in speed as quickly as it did off the mark (ie. the rate of acceleration will drop so that the rate of acceleration by 130km/h is no longer 17km/s^2)
Someone get clocked by a NON-RADAR-EQUIPPED police vehicle huh?
Sounds like you're trying to work out if they were following you for long enough to get an accurate guesstimation of your vehicles speed... That and they must have been going in the other direction when they saw you...
Am I close?
Good luck dude.
Adrian
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
