So suddenly I have a very very irritating issue with my r33. There isn't really an electrics section of the forum, but this may be audio related.
The issue rose its head on a quick shopping trip of all things. Turned the key to on, then upon turning to ignition the entire electrical system dies. No power to anything.
At the time I managed to get it back, but I had no idea how and I put it down to a gremlin. But the problem persists. Its an inconsistent problem, but I have begun to notice patterns.
Variables that have changed :
I moved from Brisbane to Canberra. In Brisbane my car was always garaged. Down here it is not. After a storm or sometimes on a frosty morning the problem appears. Also, after going to a car wash on a nice warm Sydney afternoon, the problem arose. Water a catalyst?
Just before coming to canberra I installed some new 6.5 option audio speakers in the doors. I used the factory wiring.
The temporary fix :
Slamming a door. Yeah ... Slam a door, and the dash lights flick on then off, and try again. Eventually it will kick over without cutting out. As long as it is running its fine.
I'm at a bit of a loss as to what I can do. I would like to give it a try fixing it myself before going to an auto electrician. Something I wanted to try was to make sure the factory speaker wiring was ok by soldering it to the speakers properley and then heatshrinking. I took a door trim off today just to look at it but nothing seems out of place.
:wacko:
Failing that, anyone know a good auto-electrician in Canberra, or even one in Sydney who is open weekends. I don't have all my tools down here which makes things harder too.
https://www.sau.com.au/forums/topic/411512-electrical-diagnosis-help/
The temporary fix :
:wacko:
Yes water humidity can be a issue
Really its not the speakers the door slam just shakes the car , bet if you open hand slap the car near the drivers door it does the same thing
Or a light tap on the dash or surround on the key?
check all battery connections after you clean them for tightness ,fuse box to battery connection
and if the car has alarm I would suss the connections on the starter relay ( the ignition uses multiple power paths ) are loose or even a worn key / ignition barrel from a heavy keyring ?
Try a new key if you have one ?
the fact its worse when its wet leads to a battery connection problem most likely or even a dead cell starting to play up
those are the places to look first
The circuit issue is between the key and battery but which item
Well gave everything a check and cleaned with contact cleaner. Nothing looked out of place and the fuses look brand new.
Remove the battery terminals and use a twist brush on it , and terminals inside , contact cleaner wont do crap to those
Pull the fuses one at a time and check for corrosion or dull grey blades a rub of superfine grit sandpaper on each leg and pop back in , not grind it off but just shine it and put back in , if you have any dodgy wiring taps they need to go on any item
check the 4ga and small wire that runs to starter as well they get disgusting filth and cause issues
Lots of wires look fine but fail , so a physical wiggle test is required on some
If the car has alarm ( under warranty let installer look at it ) not warranty pull off clamshell surround on ignition and recheck while wiggling the wires going into key barrel , go easy or sparks could fly!!
But save that for last
Edited by Carbon 34
The terminals look brand new I just reseated the terminals.
Haven't had a chance to test out the theories as it has yet to not start. Its warming up too. Maybe I should see if it starts after a wash.
The car has alarm, and If it continues I'll take the plastics off the steering column.
    • Just to give an update coilovers passed without any issue!
    • Ducan , yeah sure mate , the unit is https://www.carlinkit.com/ambient TBox Ambient -  plugs straight into the USB C and it runs as a android  unit and you can link your phone to it via Bluetooth , but it only allows for one phone at a time. you can download and apk files you want and load it on there , I downloaded a basic maps apk (OsmAnd+ — Maps & GPS Offline) so I can run navigation without data usage , its not as good at google or wazes but it works fine for what I need. I can put up screen shots if you like. Cheers Pac
    • Hey Team , just got the Fujitsubo unit installed , not a big db difference but it does sound better across the rpm range , I have the front pipe on order I'll post a video with sounds when that has also been installed.
    • The gearbox in my R32 GTS4 (now with RB25DET) has just over 300k on it . Life includes some track time. Has had one change of oil in its lifetime. I rev match on down changes. I don't have any problems with synchros or gear crunching.
    • Currently advertised with some A4 flyers up at work for $30k ono Will detail it next week, and get some good picks for carsales, then put the cover back on and put it back on the tender until someone comes to look at it No real hurry to sell, in saying this I would like it gone with in 6 months as I am retiring in May 25 and lose the ability to store the car undercover in a secured site, plus as we are moving out of Sydney the potential buyers market will be more limited https://www.sau.com.au/forums/topic/485907-2002-vx-ss-commodore-30000-ono/
