Hey guys hope you don't mind first post being a question been asking on 31 club but haven't had a lot of replies. I've recently installed a series 1 25 into my 31.
109,000 kms on engine
Redtop J pipe (no bov)
2.5 fmic way to big.
standard dump, de-cat and 3" blast pipes.
GFB boost controller set at 8 psi
Bosch 040 pump
As you can see it's stock. I have checked all the vacuum lines and swapped the j pipe because I thought the spring in the bov was gone and leaking. I've checked all silicone joiners. I have a boost gauge hooked up in the engine bay to help with diagnostics, no boost spiking or drop so I'd have to say it doesn't have a vacuum leak. I've changed the afm out with a couple others took a lot of the missing away but not completely. I've tried screwing the icv all the way in as well as unplugging it to see if that was the issue. I've tried adjusting the tps and put it back to where it originally was.
Now when you start it it'll idle for a few seconds at 500 then raise and settle to a thousand rpm. Between 1000 and 2000 rpm it has a slight hesitation, car will drop revs below idle when you back off the throttle. Anything over 2000rpm when you back off throttle if you don't blip it the car will completely stall. Even if you're doing 5 grand in 4th... I'm really stuck here and getting a little bit over everything if I'm honest I'd just look to put some km's on it.
If anyone has any ideas please let me know anything else to add to the list to check, and a few tips on how to check it would be amazing.
https://www.sau.com.au/forums/topic/411518-over-fueling-stock-s1-25/
Where are u located? Take it to a tuner and get it checked. Can be many possibilities
In perth 40km's from the closest tuner don't wanna drive it don't really want it to be trailered and left at a shop with an open bill. Rb25 only went in it after a 20 had spent 4 months at a professional shop that couldn't get it running. And I was left with the bill. I'm running out of money, I'm running out of patience and a shop is a last resort but I was just wanting a bit of a checklist to try from home.
The rb20 stopped fueling all of a sudden had pressure at the rail had signal going to the injectors but the injectors would pulse random amounts at different injectors and not in sequence.
Tried 3 differents AFMs
Tried 2 different ECU's
All sensors are RB25.
How do I do an ecu diagnostic?
I use my consult. But there is a way to test via engine light afaik. Cant help u on how to tho as i dont use it that way.
So u have rb25 with ALL sensors including tps, knock and afm? With rb25 loom and ecu?
Are u running stock fuel pressure reg?
Have u tried disconnecting 02 sensor and driving?
Are u running stock intake pipe to afm?
Thanks WMDC I'll have a look bud.
RB25 series 1 stock ecu and loom has knock sensors installed I'm assuming they're 25 to match the ecu? I have sexy fingers when it comes to electrics so the boys sorted it out for me. Running stock fuel pressure reg at the moment waiting til pay day to buy a nismo non rising rate set n forget incase the 040's pushing past the stock regulator. All my diagnostic stuff is for carby so can't check the fuel pressure yet. disconnected the 02 sensor and just had it stationary and it was doing all the same things, will it be different under load?
Errr cheers for the link saved it. Homeboy who wired it will bell me after work I'll ask him if he kept the consult in the wiring assuming he did and whether it would work with the check engine light on the dash of the 31. I thought they had an led on the side of the ecu that flashed.
And to the reg fair enough, I saw that it was about $100 to buy an inline efi gauge or $199 for a regulator with a gauge so I was going to buy the reg with gauge. I'll see if I can get the diagnostics checked out n see what it says. If it doesn't work on the dash can I plug an ODBII reader into it anywhere? I know my friend owns one.
No early Nissans are not OBDI or II. You need something like the ecutalk cable (or buy the display if you haven't got a laptop):
http://www.ecutalk.com/
In my Stagea the consult plug is behind the coin tray next to the fusebox.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
