Okay, back from Japan and getting into my studies and jumping into a full time job soon so this needs to go as it will be sitting in the garage collecting dust as I already have a daily.
Car: 1989 Silvia S13 Seamist Green 2 tone
Exterior:
Standard apart from mirrors which have been resprayed in the 2-tone silver.
Suspension/wheels:
Standard wheels with 80-90% tread on Pirelli tyres
Pedders comfort shocks/springs (Still pretty stiff..)
Aftermarket Castor Rods
Ultra Racing fender braces
SR20DET Slotted front brakes with new bendix pads
Interior:
Pretty much standard apart from Boost gauge.
Electricals:
Battery relocated to boot
Fusebox relocated to boot
Stinger distribution block
0 gauge wire from battery to block
4 gauge wire from block to starter/alternator
Nearly all wiring replaced/extended with new cables
RB20DET Manual ECU modded with CA body harness
Engine:
RB20DET - Seller said motor had about 150,xxxkm's~ Motor is pretty healthy
RB25DET Turbo (No shaft play)
Justjap 3" bellmouth dump (200km's old~)
Gutted cat
3" Exhaust into a twin tip muffler (Not that loud)
Hybrid front mount cooler
All cooler piping resprayed with wrinkle black
Valve covers resprayed in 2-tone silver
Timing case sprayed in wrinkle black
All coilpacks have been sealed with engineering sealant
Resprayed engine bay in OEM Green
Brand new fuel filter (200km's old~)
Brand new fuel lines (200km's old~)
Modded coilpack cover (sprayed in wrinkle black aswell)
Brand new GKtech coolant reservoir (un-used)
Replaced GNC turbo/manifold gaskets (200km's old~)
Billion thermo heatwrapped front/dump pipe (200km's old~)
Most exhaust gaskets replaced (200km's old~)
Most sensors adjusted/replaced
Brand new size 52 Sealed Century battery with 2 years warranty (Still has over 1.5 years of warranty)
Most vaccume (If not all) lines have been replaced
R32 GTS-T AFM (Opened, resoldered contacts, resealed - Flushed element etc)
Most nuts/bolts/screws replaced
R32 GTS-T Radiator with aftermarket thermo (With switch) (Flushed several times before installing)
Aftermarket thermofan with switch on dash
Braided HEL Clutch line
S13 SR20 Clutch master cylinder
Rust has been cut out of sunroof (Common). Currently in primer around sunroof.
Rust has been cut out and fixed on firewall aswell (Has been resprayed after).
Car doesn't have aircon/heater (Should have all the parts to put it back on if the buyer wants though).
Around sunroof is currently sprayed in primer/putty after cutting out the rust.
There's plenty more info that I'm forgetting but to refresh your memory, just check out the build thread:
http://forum.jdmstyletuning.com/showthread.php?34785-Project-S-MUOI-BA
Price: $4,500 FIRM. (Please no low ballers or time wasters, I really don't have the time!).
Apologies for people that had contacted me before and never got a response. I had plans to finish the car but have currently purchased another project car so the Silvia will be sold at a cheaper price as there are a few things required which I will explain now.
R32 GTS-T RPM Cluster needs to be fitted onto the S13 Cluster (direct replacement) to get the RPM working as it currently doesn't work (4cyl rpm tach doesn't read the RB20 6cyl).
Speed sensor needs to be hooked up as speedo currently doesn't work.
Fuse box needs to be mounted in boot and just a general clean up of the wiring in the back. No cutting/splicing/rewiring required. Just needs a clean up.
Rear seats need to be mounted in.
ECU needs to be mounted (have SR20 ECU brackets which can be used on the RB20 ecu).
Few exhaust manifold studs are broken so a bolt extractor will be required to remove and replace (car still runs fine, but it's what I would do regardless).
Few interior plastics need to be put back on.
Fuel pump float needs to be replaced (have a spare SR20 fuel pump with float, just need to install it). I was hesitant as the car has a fuel tank of fuel and cbf submerging my hand in fuel
It's just simple stuff really that I cbf doing. Got too many cars and running out of space so price has been reduced to a hassle free $4,500 to get rid of it ASAP. Part it out, drop a SR20 NA motor in it and sell it for double.. Whatevs.
Just to name a few..
No joyriders or P platers.
https://www.sau.com.au/forums/topic/411547-silvia-s13-rb20det-2013-rego-4500/
  • 3 weeks later...
