Wouldn't you lose all tunability with 2000's? That's what ill do if not but I always though huge injectors were a pita to tune.
No. My 2000's idle and drive SO MUCH BETTER than my 800's could ever dream of.
I was going to say that I think it was Guilt Toy that hit the wall with 740 Nismos at around 360 Kw on his RB2530 burning E85 . I'm also using these but if I had my time over I'd have bought the ID 1000 version of the Bosch EV14s . Your calls but 2000cc injectors are huge like enough to empty your full tank in about 4 1/2 minutes (12 x 4.5 = 54L) .
By my rough dirty calcs based on GTs results 1.25 x 360 = 450 so thats possibly where the ID 1000s would get you if your pump/s and everything else could keep up .
A .
A .
Depends on the setup and tuner. N1GTR's car called it enough at 403 rwkw on 1000's, now runs 2000's.
All this talk about "oh they're so big, the driveability, idle and fuel economy will suck", go for a drive with them installed in a car. Injector technology has moved on fromthe mid 90's or whenever stuff like the Sard/Denso/Nismo/whatever were designed!!!!
A .
The 2000's are actually 2200cc at 45psi I think.
The 1000's are around 1500cc at 80psi.
For the small price difference the 2000's are the go, around $110 each now I think. Keep in mind they are natural gas injectors and may not last as long as the 1000's from what I am told. From SAU feedback there are no issues so far though.
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
