Honestly, if you are sick of the sound I know where your coming from, thats why I changed mine
And it doesnt really matter what you choose as long as its a plumback, there are to many issues with the Atmo BOV's (Search and you will find) so make sure you get a plumback
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579403
Yea Cal, pretty over it, its a bit boring i guess lol
I have heard about a few good read ups on the Gtr ones so might give one a go.
And remember dude the coast is still pretty hostile with the boys in blue so keep it legal :thumbsup:
Maybe see you on Sunday?
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579462
are the stock ones good enought for gt30's? must be alot of air to move for the blow off valve.
when i back off the throttle im getting a quietish zututututu...
Edited by SliverS2
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579473
Mine failed a long time ago, it was sticking open and not getting boost etc..... Not commen from what ive seen but made a big difference when i put the new plumback on and got some zutututu action too :P
Yep ur not wrong Mat, thats why im trying to keep things looking stockish i guess ha
Yea man possibly, i will let u no during the week for sure, cheers
Yeah good plan, keep out of trouble!
Let me know if you can come say G'day and meet some of the members even if you cant make the run :)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579484
AFAIK the stock BOV works fine on most Gt30 series turbos, plenty of people running GT3076's etc with stock/GTR bov's
Mine is a Greddy Type RS Rip off, but im Considering getting a genuine. So if that happens I will probably sell mine which has a custom plumback adapter on it (as the genuine one doesnt fit and the rip off doesn't come with one)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579490
Haha im hoping so. Yeah man for sure im pretty keen, hopefully install my coilovers this week, would be sweet to give em a run
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579535
I think its the pressure that is a concern for them sealing, and they do flutter to a degree so its obviously a lot of air but alse depends on the position, factory position is pretty good as its close to the TB, the GFB one i have now still flutters a bit even on soft setting, but its a LONG way from the TB.....
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579536
Mine went on on the weekend, have a look -
http://www.skylinesaustralia.com/forums/topic/358438-34geeteetee-daily-track-project/page__st__400
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579537
Thansk mate, if you dont make this cruise dont worry as we plan on doing stuff at least monthly! November will be an exception as a couple of us are entered in the SAU Nats :D
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579547
Sweeeeet, sounds good man!
If you join as a member there is a members section with a Newy/Coast chat thread where questions like these will be answered by the guys for ya :D
Plus for the price of membership you get a heap of value, stickers, lanyard, shirt and discounts off purchases at some places AND it give you better pricing for events etc :yes:
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579557
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
