Considering going with one of these for my new 25/30 build up.
Have search on here but doesn't seem like anyone has really used one of these?
Just wondering if anybody has had any experience with one of these kits or any similar types of setups available that are more cost effective which is still in tank?
Any help appreciated
Give Wing a call at alpha omega
He just finished my twin intank pump surge tank
Awesome bit of kit
http://www.ao-ps.com/
He just finished my twin intank surge tank
Awesome bit of kit
Chequered Tuning sorted one out for a 500wkw+ 34 R, i think running a couple of those new Walbro's that everyones finding to be good choice with E85 - all went together ok as far as i know
Can run 1,2,3 or 4 pumps
Has the capability to have 2 lift pumps fed into it
There's a variety of pumps that can be used Inc Bosch, deatschwerks, walbro pumps and other big brands
If you had the fuel requirements to run 4 x walbro 400lph pumps, you could easily afford to upgrade your charge system.
As Piggaz said I'll just be using 2 pumps which is plenty for my requirements
And the size of the surge tank is the same for all applications ranging from 1,2,3 etc pumps? I would be interesing to see how if at all it affects fuel temps over various applications
Id say if you're gonna run 3 or 4 walbro mofo's you might wanna look at running twin feeds.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
