Considering going with one of these for my new 25/30 build up.
Have search on here but doesn't seem like anyone has really used one of these?
Just wondering if anybody has had any experience with one of these kits or any similar types of setups available that are more cost effective which is still in tank?
Any help appreciated
Give Wing a call at alpha omega
He just finished my twin intank pump surge tank
Awesome bit of kit
http://www.ao-ps.com/
He just finished my twin intank surge tank
Awesome bit of kit
Chequered Tuning sorted one out for a 500wkw+ 34 R, i think running a couple of those new Walbro's that everyones finding to be good choice with E85 - all went together ok as far as i know
Can run 1,2,3 or 4 pumps
Has the capability to have 2 lift pumps fed into it
There's a variety of pumps that can be used Inc Bosch, deatschwerks, walbro pumps and other big brands
If you had the fuel requirements to run 4 x walbro 400lph pumps, you could easily afford to upgrade your charge system.
As Piggaz said I'll just be using 2 pumps which is plenty for my requirements
And the size of the surge tank is the same for all applications ranging from 1,2,3 etc pumps? I would be interesing to see how if at all it affects fuel temps over various applications
Id say if you're gonna run 3 or 4 walbro mofo's you might wanna look at running twin feeds.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
    • I couldn't agree more. As an owner of a built high HP skyline, I'd be a hypocrite to not buy a Hummer for the reasons you listed though haha.
    • Hahaha oh shit! Again!
