Hi Guys,
I got a Cobb and have been using Stage 2 & LC5 for my ADM2009 on the road since. Great burst of power and improved drivability.
(I'm on 98RON Shell vPower, HKS res midpipe, K&N air filter element)
I took it to Phillip Is (18 deg C) and Sandown yesterday (23 deg C).
I noticed flashing of the boost gauge - which I think means that there is "knocking". This usually happens after the 3rd or 4th lap, especially if I hit the rev limiter. Sometimes it occurs even at 5000rpm in 2nd gear and tends to linger for about 5 to 10 seconds. I feel the car is not as fast as it normally is.
How do I fix this?
Is this BAD for the engine?
Thanks in advance.
https://www.sau.com.au/forums/topic/411598-knocking-with-stage-2-cobb/
Thing is, it doesn't do it when I drive on the road.
The Stage 2 is the Off-the-shelf map that came with the Cobb, which I thought was conservative.
What parameters should I log?
Thanks for the reply, Martin. I received your Trans Fluid 35TML last week and filled it up before Sandown. Goes nicely.
Sounds just like the tune is street conservative, but not track conservative (3-4 laps heat++ etc) - they are two totally different scenarios really.
Good news is it's not a major fix required, but certainly shouldn't keep trying to replicate it! Knock = bad.
So maybe after 2 laps have an easy 1 rather than going for 3-4 (until its fixed) :)
Does that meant if I get a track-oriented tune, it would generate less power? Because it would have to dial down the timing or boost to cope with heat.
Would larger injectors to fix this?
No point in speculating about it, you need to generate a log of some third and fourth gear pulls and then let me have a look through it. Either that or get the right map for your car running Aussie 98 fuel - such as the tune we supplied for Duncan Forrests GTR that won the NSW Supersprint championship two years in a row. No knocking, plenty of power.
OTS Cobb maps are ok, but they tend to not be a bit sketchy when pushing the limits of our 98 fuel - as they simply dont calibrate on it in the US. Regardless of what you do, that flashing engine ligh it something to take note of, and try to avoid if the idea of rebuilding an engine scares you even just a little bit :)
If you want someone local (Bayswater-Vic) the guys at Racepace can put it on the dyno for you and they have the Cobb tuning software.
9762 9421
But I've seen a few R35's knock at Sandown and PI as they have a lot of engine load at those tracks.
Ok maxzugkraft I have had a chance to have a look at a few of your looks. Looks like the tune is working really really nicely, the only time there was any indicated knock (false knock) was when you shifted on the rev limiter. The yellow line in the picture below is 'knock' and as you can see it stays on zero the whole length of the run...which is very nice :)
Thanks Martin.
I can't see your picture. There is a question mark instead.
Will this tune work for warmer weather? 25-28deg C?
Bear in mind the log was done at 15 deg C ambient temp.
Is it running too rich, as I'm getting a lot more black soot on back now.
Thanks Martin.
I can see your screenshot now.
Now I can use full power without holding back!
Can't wait to get back on the track!
Hope to see lap times plummet.
Good job. Cheers!
9762 9421
Would you recommend some further intercooler upgrades on top of the custom dyno tune?
Pinging at 18degC or 23degC ambient temp is pretty bad.
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
