Hi all,
wondering if anyone has anything similar occur....
Basically on startup, the power steering is very noisy but then goes away once the car has warmed up.
The power steering pump has had a full reco around 18 months ago. Before then, the noise was constant.
Any help would be greatly appreciated.
cheers
Is the fluid aerated/bubbly in the reservoir?
100% its p/s? Dropped the belt and rechecked ?
Would suck if say it was an idler or tensioner pulley and just sounded like it was coming from p/s pump area then let go
Not sure, it's just really strange that on a cold morning startup the car is fine, no noises. If right then I do a dry steer, the loud noise starts. Once the car has warmed up a bit, it's all perfect and quiet!!! What the!!
  • 10 months later...
Pulling this up from a year ago but did you ever fix this problem....mine started doing this exact same thing this morning :(
this was the symptom of mine as the power steering pump was getting on - noisy when cold and dry steering, then would go away.
it will gradually get worse if it is indeed the PS pump.
bottom line is you can leave them for a while without any trouble.
Mine started having a noticeable effect on the slow speed steering when the car was still warming up until I did anything (replaced the PS pump).
good luck!
You can try replacing the fluid to help with cold temp steering. As fluid gets old and sludgey and is thicker than normal when cold. This means it isn't lubing the system as well. Draining the fluid and replacing it with fresh fluid can help.
I have to get around to doing it to my Commodore at some point (when I could be bothered, along with finding the cause of the slight misfire it has). had a leaky pump for ages and had put some stuff in it that was supposed to slow/stop leaks. Basically it was a thick fluid. I finally got a new pump but didn't completely flush the system (just topped it up really), so on cold mornings the steering has a bit of a notch just off straight. Once it warms up it's fine. I did some googling and that's when I found out about flushing the system (which made sense, since the fluid is thinner when warm, and on really cold mornings it was much worse, to a point where on a sub zero morning I had no power steering the first time I tried to turn the wheel).
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
