Rb25Det Gearbox W/pp Converter, Npc Twin Plate Clutch & Os Giken Flywheel, Garrett 2860-5's, Tomei Manifolds And Dumps Suit Rb26
Accepting Closest Offers. No swaps.
Pickup is fine and can also organize postage (at buyers expense obviously)
R34 RB25DET Gearbox Rebuilt 12,000K Ago has OS Giken Push Pull Converter for 33,32 Push Style Clutches $1700 with PP Converter
Will Separate $1350 For Box and $350 for PP Converter
Shipping Quote from Pack and Send to Sydney $180
Garrett 2860-5 Turbo Kit with Tomei Expreme Manifolds and Tomei Dump Pipes - $3250
OS Giken Clutch and Flywheel (NPC Twin Plate rebuild to new 12,000K Ago) - $800
  • Replies 41
New to the forum. From Canada actually, so if you were willing to split the turbos i may take the manifolds if you were willing to ship to Canada. If the price is right.
BUMP PRICE DROP!
Sitting around to long, collecting dust
RB25DET Gearbox Rebuilt 12,000K Ago has OS Giken Push Pull Converter for 33,32 Push Style Clutches $1600 with PP Converter
Will Separate $1300 For Box and $300 for PP Converter
Garrett 2860-5 Turbo Kit with Tomei Expreme Manifolds and Tomei Dump Pipes - $3100
OS Giken Clutch and Flywheel (NPC Twin Plate rebuild to new 12,000K Ago) - $600
Accepting nearest offers
Tomei Manifolds Sold Pending Payment
Price update -
Garrett 2860-5's $1800 or closest offer
Tomei Dump Pipes $650 or closest offer
RB25DET R34 Gearbox Rebuilt 12,000K Ago $1300 firm
OS Giken Push Pull Converter $300 or closest offer
OS Giken Clutch and Flywheel (NPC Twin Plate Organic, Rated to 1000HP) $600 or closest offer
Or take the GearBox + PushPull Converter + Clutch and Flywheel for $2000 firm
Make some offers :)
**I have original receipt for turbos and push pull converter
I'll have a look for original receipt for Dump Pipes as well
Items are in Brisbane but willing to ship anywhere
Edited by rb26me
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
