as in the : http://www.skylinesaustralia.com/forums/topic/346667-servicing-your-v35-list-of-whats-needed/ the best i have used and still use is Penrite SIN 600 (super DOT 4) realisticaly brake fluid is still brake fluid you will only see minor differences but for the best results i do recomend either the Penrite 600 or MOTUL.
https://www.sau.com.au/forums/topic/411628-brake-fluid/#findComment-6581200
For a normal road car, you will be fine with a decent qualtiy 'off the shelf' dot4 fluid.
If you do any track work, or other driving which requires excessive repeated braking, then go with a higher spec fluid with a higher boiling point.
https://www.sau.com.au/forums/topic/411628-brake-fluid/#findComment-6581274
Thanks for the input. Wasn't sure if Penrite was the way to go. Little sceptical after their motor oil assisted in blowing up my previous SR20... :/
Pretty sure the Penrite Sin 600 is in the DIY servicing list of oils to use for our car, that's where i got it from
https://www.sau.com.au/forums/topic/411628-brake-fluid/#findComment-6581324
My brother-in-law linked me to this a while ago.
http://www.animegame.com/cars/Oil%20Tests.pdf
While it's specifically for engine oil, it just shows you how 'expensive' brands can absolutely suck.. So, it's good to do your research! I usually put Mobil One Gold bottle in, and the chunk that was left was the biggest there! I'll be going for Royal Purple next time..
As for brake fluid. TRW GP600 Brake Fluid is what I normally use.
https://www.sau.com.au/forums/topic/411628-brake-fluid/#findComment-6582223
http://www.animegame...Oil%20Tests.pdf
that link is great !
But not vq35de specific.. Royal Purple is actually not that great in our engines.
Mobil 1 and shell rotella t6 seem to do well.
https://www.sau.com.au/forums/topic/411628-brake-fluid/#findComment-6582735
Interesting read, but not really relavant, you can't just do one test and then proclaim the oil that performed best in that test as the most appropriate oil for any engine without testing all other conditions the oil will face inside an engine. Especially if the test conditions exceed any conditions found in an engine.
https://www.sau.com.au/forums/topic/411628-brake-fluid/#findComment-6582859
Depends on what the intervals are. Synthetic left in there for 20k kms will turn to liquid faeces. Crappy spec oil will do tops 5k i reckon.
However if you're doing changes at $60/bottle every 5000kms it works out to be more exxy than $100/bottle at 10000kms. Both will be in very similar condition at the end of their relative lives.
However, if you speak to Harold at Performancelub.com you can get 5qts of Royal Purple for about $70 or Mobil 1 for $65. WIN!
https://www.sau.com.au/forums/topic/411628-brake-fluid/#findComment-6585777
