I use two waxes
1) for the body in general, a high quality Canauba wax eg Meguiar's Hi-Tech Yellow Wax #26
2) for taking off soot & discolouration from the rear bumper whilst running rich, Malco Nanotech Banana Wax. This product negates the need to use polish. This wax also permits the sealant to remain on top of an existing polished surface.
The overall process is still...
Wash > Clay Bar (if required) > Polish (of correct grade and best type) > Sealant > Wax
https://www.sau.com.au/forums/topic/411635-best-wax-to-use/#findComment-6580886
It's true that without knowing how the car was treated by a former owner, we don't know how thick the existing paint is on each panel. This can be resolved by asking your local panelbeater or SAUer or Detailer for a 15 minute loan of a paint thickness gauge > thickness in microns = ???
Anything below 120 is thin and extra care needs to be taken if compounding/polishing.
But getting back to waxes, wax doesn't thin the paint. It coats the paint or sealant to give you a shine.
https://www.sau.com.au/forums/topic/411635-best-wax-to-use/#findComment-6580908
  • 5 weeks later...
I stay away from any product that claims to be both a polish and a wax.
In between the polish and the wax should be the sealant which does several things which shouldn't be understated.
True true, best method is to always start at base one as terry mentioned and ensure you start with a solid clean, the clay bar, moving to a polish/wax remover and then progressing from there into a more detailed polish again and finally sealing with an appropriate wax.
Again, this is all subject to time and budget...and the condition of your car
https://www.sau.com.au/forums/topic/411635-best-wax-to-use/#findComment-6626514
Hi guys,
For anyone out there that is not running a cat.... hmmmm. During a SAU detailing day, we tested 7-10 different products and found that one in particular worked extreamly well. P21S Total Auto Wash. Spray on to the area, let it site for 30Sec and wipe with a Microfibre cloth, gone.
For a wax there is a Japanese wax we have by Ion Coat called NAVI WAX. It is our best selling wax. There is a light and dark version. Very easy to use.
  • Wet the supplied applicator sponge.
  • Apply to a panel at a time
  • Immediately wipe of the panel with a high quality microfibre.
  • Continue around the car.
If you notice any hazing or smearing, go over the car again with a wet microfibre cloth then buff dry lightly with a dry MF cloth. Amazing depth and gloss.
https://www.sau.com.au/forums/topic/411635-best-wax-to-use/#findComment-6631401
For a mid range wax i have used both the P21s wax and also the Pinnacle Sovereign wax. Both around the $60-$70 dollar mark but last for ages.
With these it is very important to make sure your paint is clean and well prepared. The results are just much better.
https://www.sau.com.au/forums/topic/411635-best-wax-to-use/#findComment-6638645
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
