I've got a project in mind for when I get another R34 and I know I'll need the extra juice so. I know secondary batteries can be installed, BUT what I want to know is:
- Can I run a parallel circuit from the alternator to the battery to charge both main and secondary at the same time?
- Can anyone post a picture of the REAR R34 GTR battery, where it sits and positioning?
https://www.sau.com.au/forums/topic/411647-secondary-battery-r34-gtt/
Yes you can run two batteries isolated , one front one rear, isolators can be purchased cheaply
Charges mains first then secondary as needed
Overall takes more current and produces heat
And needs long runs of large ga wire as well
Or parallel strapped together as one as long as purchased together new and same models etc like two dry cells ?
Or a battery and battcap in rear not isolated
r34 gtr batteries go in the same spot as factory cd changers on gtt passenger side under speaker
Depending on what you plan on running I can design a solution for it
