Hey everyone
My name's Shravan and this is my new 1998 R34 GT-T!
Pearl Black
Sunroof Option
Front Lip Bar
NISMO (I think) LED Tail lights
Kakimoto Regu06&R Cat Back Exhaust
Some form of upgraded actuator (boosting around 0.7 - 0.8 bar)
and I think the 2 stage boost has been permanently grounded
Paint was in pretty bad shape, knicks and dints were a little common, until a 2 day detailing session last weekend (see below) :)
Will take some more pix when I have the time..
Anyway hoping to come to some SAU events in the near future to meet fellow skyline enthusiasts!
Edited by fusion07
https://www.sau.com.au/forums/topic/411663-hello-from-brisbane/
  • 7 months later...
I have done some mods to it so far, coilovers wheels and a few other things, was thinking of starting a build thread considering this is just the intro section :P
Plans so far are just to have it as a daily / streeter..not looking for too much high end power at this stage, prefer bottom end torque / midrange / nice handling mods, helps a lot on Mt Nebo runs ;D
Awesome GTT :yes:
Detail job come up smick!
They are a damn good car, have had mine for years and plan to have it for years to come :woot:
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
