  • Replies 63
^^^ I can't believe Loz is selling it .... (he is the owner of Hardtuned.com for those not in the know). And I can't believe he isn't advertising it with pictures of Lauren draped over it :)
Had no idea i was just trolling around carsales and thought i'd search Infiniti and stumbled across it. God damn she is seriously hot, i would make her breakfast in bed.
Saw him parked outside the shops a few weeks ago, looks amazing. No pictures can do it justice. Suprising i've never seen him at any events or anything before though.
I am in the hunt for a black V36 in the not too distant future .... when you are on the pointy end of selling it and have had a few price drops, PM me Mike :)
I have been looking at this one .... so cheap! Moderately high kms, but the price is right!
http://www.j-spec.com.au/dealer/2008-Nissan-Skyline-7098270.html
When pricing yours Mike, keep in mind that Loz's has nearly $11k of wheels, custom air bags and brakes on it, plus every option available for the V36 (some of them from the USA and are not even available on the V36s out of Japan).
I'm not gonna compare mine to Loz. His is extremely modified. Mine is stock throughout besides aftermarket wheels and a Japanese tv tuner still in the boot. The car has been mine for over two years and have only put 10,000km on it (sitting at about 25,000km now). It's hardly driven because I work from home and when Im not here Im traveling around asia for work. It'll probably be the best value on carsales though when I put it up given the condition, low KMs and price (just waiting on my visa appointment on monday).
http://www.j-spec.co...ne-7098270.html
Holy GOD thats cheap!!!???!!! Even with those km's they still normally go for around 2M yen.
EDIT: *Smacks Forehead*
Just realised that its the base model.........
Edited by Alkatraz
But what is the base model missing over the SP? Full leather seats and paddle shift I thought. The paddle shift kits you can add for $350, and having half leather seats (which is what I have now) is no big deal to me.
4 wheel active steering, 19 inch rims, bose sound (actually think that maybe an option still), big brake kit, aluminium pedals, adaptive steering wheel and mirrors, sports suspension. I think that everything else is an option. If you are happy with the half leather then go for the S if you can, you get pretty much all of the above and have the choice of a manual box.
Edited by Alkatraz
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
