who/ where in adelaide should i go to have a skyline gearbox either rebuilt or bought and installed, preferably an exchange arangement?
got a 32 with a stuffed gearbox which i am hoping to have taken out and a 2nd hand one exchanged in, maby rebuilf the stuffed one depending on cost differenced.
looking city to north, nothing south
https://www.sau.com.au/forums/topic/411681-adelaide-gearbox-specialists/
If you can get the box out yourself, take it to Richie (R Spec Gearbox) His number is 0400523308. He did the box in my GTR and is an absolute champ. Cheap too, can't recommend him highly enough!
Haven't needed to use these blokes, but have heard they know their stuff from several folks:
Precision Differential & Gearbox Centre
552 Port Road
Allenby Gardens, Australia, 5009
SA
-D
I booked my car there yesterday, for next friday...see how it goes!
whats a gearbox recon worth, just a 20det 5speed, not a highpowered car or money pit, just a secondary project car, just needs to be done at a decent price, decent time frame.
Edited by GH05T
What's a good way to check whether a gearbox is in good cond.? Looking at buying the same one (RB20det 5spd) because the one in my friend's car isn't gonna last too much longer. Any other suggestions that doesn't include a completely new gearbox? Thanks
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
