Hey guys,
When im breaking i can one loud "clunk" coming from under the car, its hard to pin point where abouts though and its driving me nuts! Its just the one "clunk" the after its happened it will only do it again after ive put forward motion then break again.. Any ideas??
Braking ? Not break dancing lol
Loose rim lug nuts?
Loose caliper bolts that rock the caliper back an forth on and off brakes
Brake pads without a shim ? If required ?
Loose pads /pins holding the pads?
Suspension bushings or joints loose?
something unrelated loose hitting / loose battery tray hold downs ?
Water bottle or junk in the boot or under seat?
If its on and off power then it would be axle , diff, propshaft or tranny related
All the above can be a serious problem so check the first on the list before driving more
Edited by Carbon 34
Its the breather for the gearbox. Its usually held in place by one of the bolts that holds the gearbox on. Just tie it down to secure it. Next time you do the clutch it can be reconnected.
When i had clunks like you it was castor aka radius rod bushes.
