Hi all,
First post here, have been a skyline owner for some time. I'm driving a bog stock R33 GTST S1 (1994) with approx 170xxx km's on the clock. During some routine maintenance (I'm a mechanic by trade) I've discovered oil in my intake, from which I deduce my turbo is on the way out. I doubt it has been off the car since production, so it's no real surprise it's on the way out.
Anyway, I have no real desire to chase big power out of the car (it's my daily driver and don't want to send my fuel costs through the roof) so I'm simply thinking of replacing the turbo with another stock turbo after getting it rebuilt. However, if I can, I'll stick another turbo onto the stock manifold and just keep the stock wastegate and run standard boost through it so I don't have to modify the stock computer and injectors.
So! The question I'm asking is, can anyone put me onto a brand/make of turbo that I can simply bolt onto the existing manifold/dump pipe? Otherwise, I'll just chase down another stock turbo and rebuild it.
Thanks guys.
(p.s, if there is another thread with this information, put me in that direction and I'll delete this one)
https://www.sau.com.au/forums/topic/411705-r33-stock-turbo-upgrade/
  • Replies 60
Depends how much is in the intake mate. It's a common occourance as oil get out top of rocker covers and is fed back to inlet of turbo making it look bad.
Maybe check shaft play of turbo and if its minimal up/down and no end float then its prob fine and its just 170k worth of accumulation
Putting someone elses stock (ceramic) turbo on your car is taking a big risk, you don't know how it's been treated or how high boost they put through it. You're better off getting a turbo shop like Hypergear to highflow it and replace the ceramic wheel with metal ones.
Just get a stock one highflowed by Hypergear, you can run it as the stock turbo if you want, or if you want to tune and boost up will make good power with good response, plus it's not a random ceramic that's going to blow up, it's a rebuilt steel wheel turbo, definite win.
Bw33zy, if your looking at getting rid of your old turbo soon then I'll take it and.get it high flowed. Looking around at prices of rebuilt OEM turbos so we'll see how that goes.
Okay sweet, well Im only just down on the central coast. I am looking to make around 250-270kw so will be possibly getting a hypergear turbo, nistune and supprting mods
Another related question... can you just buy a new turbo with a t3 flange and bolt it on using the same actuator etc?
You could, but those ling long turbos off eBay are junk. Better off just getting an used high flow OEM turbo that is in decide nick or just send your turbo to hypergear and get it rebuilt for peanuts
If u do get a highflowed turbo as the boys are suggesting the ecu will need to be upgraded,
So it all depends on what ur plans are for the car on whether u should upgrade the turbo and ecu etc.
As was said already the oil may be from the rocker cover breathers rather than the turbo seals themselves.
I recommend cleaning all the piping and installing a catch can in between the rocker cover breathers and the turbo intake pipe, this will stop nearly all of the oil buildup.
By all means tho if u wish to upgrade the turbo u should but within a few thousand km's theres a good chance the oil buildup will return to the intake
Would an ecu upgrade be needed if I'm running.stock boost (7psi)? I wouldnt have thought so...
Last r33 i had come in was running very poorly due to r+r with the highflow.
The r33 ecu's are very sensitive to airflow changes and get upset easily.
Not saying u deintely will need it but just be aware its possible,
But remember it may not need a new turbo just because of the oil in the intake pipe.
Another question... Anyone ever put a Garrett GT3582R turbo on their RB25? I.e do they bolt up to the stock dump pipe? Can get ahold of one for around the same price as a highflow on my stock turbo.
lagggggggggggggggggggggggggggggg monster, and from other cars I've seen you will need a spacer plate, new lines and a 5x bolt dump to down pipe, not to mention the intake pipe will need to be modded or replaced
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
