NA rb's most certainly do NOT come with 2.5" standard. unless you bought your car new from nissan you can't say that it has the stock exhaust. more than likely your car has the exhaust from a turbo r33, which run 2.5" standard. and make sure you measure inside diameter, as that is what they use when measuring exhaust size.
While installing my muffler the inlet matched the exhaust pipe which was 2.5 inch, the n/a r33s came with 2 different exhaust styles, some came with a butterfly valve from factory(my exhaust), some did not. I know for certain my r33's exhaust is from factory since my friend has the exact same car, and his exhaust is also a 2.5 inch with a butterfly valve on the right tip. I know im right since i actually welded the muffler on myself.
as for 2.5L exhaust size vs 3.8L exhaust size, you have to take into account the rev range of the car as well. obviously a smaller engine that revs higher will flow similar amounts of exhaust gas at high rpm, but at the lower rev range it will flow less. the wider the rev range, the harder it is to get an exhaust size right. 2.5" is probably good for a 2.5L engine if you are going to spend a lot of time at high rpm, but if you only cruise around at lower rpm then it will drone like a mofo (as most people find out), as well as not flow as great as a smaller diameter pipe (so give you a bit less torque).
2.5L screaming at max RPM of 7000RPM = 8750 Litres per minute of air ingested (At a perfect efficiency, but in actual fact it will be closer to 80% of that number)
4L (Falcon) tipping over at 6000RPM is 12,000 litres per minute of air ingested.
Take into account they're both NA, exhaust gas temp should be relatively the same, meaning that the exiting gas volume should be quite comparable.
I'd run the 2.5" on the 4L, and a 2.25" on the 2.5L as it doesn't need the high end gas flow, as it just doesn't have the need for it.
while i agree with the point you are making, you can't simply apply that sort of basic calculation to it. it doesn't take into account the difference in intake efficiency, which then also determines the amount of fuel that will go in and what sort of bang you get.
given that the majority of older commodores and falcons only rev to 5000 (falcons) and 5500 (3.8L commodores) and only put out similar max power to the skyline, they would be put out similar sort of amounts of exhaust gas.
as for the 2.5" stock exhaust, your mate's car may have also had a turbo exhaust put on because they didn't come out with 2.5" stock, as that is the size they used on the turbo skylines. given that on their 2.0L engines (such as the sr20) they weren't even using 2", they certainly wouldn't be going over half an inch bigger for only half a litre bigger engine.
4. Don't come back in A months time and complain that it's Droney, audibly loud natro skylines will be Droney on the highway, don't like it keep it quiet it's as simple as that.
+1 to that.
I have a 2.25" mild steel catback, no reso(i know it's silly), and a small muffler (red back i think) and on the highway it is just so droney.
Not worth your money and efforts is my 2c
Yea you might be right, ill look into it, maybe its just from the resonator onwards thats 2.5inch, rest might just be 2.25.
  • 5 weeks later...
Just stay with stock, iv'e currently got a stock system with cannon muffler sounds not too loud but still gets the police attention as i got defected for it and he didn't even hear it.. just asumed its too loud coz of having a cannon..., will be switching the muffler back to stock
Na if you did that you would lose all the backpressures and then lose so many killerwasps.
although everyone know noise=speed therefore more noise obviously = more speed
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
