Hey guys... looking into a stronger alternative gearbox for my drift car and someone mentioned jerico boxes. I did a bit of searching on them and it seems they fit the bill.. strong, light, dog engagement and best of all cost effective. Has anyone done the swap and if so whats involved? i realise a lot of custom work will be required but i can do all that.
https://www.sau.com.au/forums/topic/411760-jerico-gearboxes/
Well they are just a fancy dogbox toploader mate, so whatever that takes, i had one for a street rotary,
i thought about putting it in my R31, but it would smash borgys and tailshafts drag racing
, so sold it and went powerglide
cheers
darren
Edited by jet_r31
Jericos aren't a bad thing.
The 4 speed is the controlled box for the new Zealand touring car category & for the v8 Dubai series as well. In the dubai series they run an external sequential shifter that is similar to the ikea shifters, Aussie designed and built too.
They have Massive ratio range and their service is rather good.
shitloads here in vic and cheap, had heaps on info on my facebook page awhile back, was going to make sr and rb bellhousings but i got lazy. i know of one place that has around 30.
Use this shifter and you are king :P
pm me with everything you know dude :D
Where are they $880 ?
I would like one for my 33.
Thanks, Mark
Renegade don't do a shifter for the r33.
They don't do one for the 5 speed Jerico either last time I spoke with them about converting one of the touring cars over
They were working on a 6 speed tremec shifter though.
You won't get one behind a GTR. You've got to remember they are essentially an old top loader box with straight cut dog engagement arrangement. They use a pissy extension housing and external selector linkages.
These are in no way comparable to a top shelf PPG or hollinger H pattern box.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
