For a mild rwd engine they will be fine. They don't have a massive torque threshold like others but that's mainly due to the compact size.
As a guide the nz touring cars have around 450hp and 600-700nm from memory.
The boxes are very reliable behind those engines.
The Dubai guys do break them with the sequential shifters but watch some YouTube in car footage and you'll quickly see why they break them. It's no wonder Mal rose wiped the floor clean when he did a round over there.....
I haven't done the conversion from scratch but I've fixed a car that had a bodgy job done of the conversion.
We had to trial a couple of diff ratios to get a decent spread.
Works okay now the clutch and flywheel issues are sorted.
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
ok got it all in and up and running... was a bit of a headache but well worth it.
parts needed
3/4 bore master
quarter master hydraulic release bearing with custom made bearing extension to sit the bearing closer to the clutch
bellhousing
gearbox
custom tailshaft (i modified the front section of the stock s14 shaft, length is almost the same) yoke is Turbo 400 32 spline output shaft.. its huge!
custom gearbox crossmember
clutch (i used NPC rb clutch but with the spline changed to Chev 26 spline input shaft)
custom spigot bearing ( machined one up to suit the auto spigot area in the crank and protrudes out
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
